Differential Chatter
Old Feb 9, 2007 | 02:33 PM
payJD's Avatar
payJD
1st Gear
Default Differential Chatter
The differential in my C6 really makes a fuss on sharp turns in cold weather. Just wondering how many of you have the same problem, and does changing the lubricant and putting in the additive really resolve the problem?
Old Feb 9, 2007 | 03:21 PM
Vet's Avatar
Vet
Check out the first several posts at the below link.
You will hear an assortment of answers to your question... the full range from some reporting success just by merely putting in extra additive to others having their clutch packs changed and STILL having chatter. So... there is no definitive answer and probably never will be.
Some people have experienced chatter after a few thousand miles of ownership and others have reported going past 30k miles or so and zero chatter. The whole chatter issue seems to be luck of the draw.
I started hearing chatter in my car... I changed the oil and additive in my differential exactly per the GM TSB and the noise went away immediately. Noise has been gone for probably about a thousand miles now or so and everything is fine. Others who have also changed the oil / additive have also reported initial success but then the noise returning after about 2k miles though. Some have reported better results. Again, luck of the draw.
It is quick, easy and cheap to simply change the oil and additive in your differential... I'd say start with that and see how it goes.
http://forums.corvetteforum.com/show....php?t=1497063
Old Feb 9, 2007 | 03:33 PM
pit-pony's Avatar
pit-pony
Mine had it the instant I took delivery, they changed the oil & added the additive but I don't have a chance to drive it as it's still winter/salt. Tech said to drive it 800 km or so to see before they contemplate changing out the clutches.
Incredible for it to be like that right from the factory.
..jack
Old Feb 9, 2007 | 03:36 PM
cdrymalla's Avatar
cdrymalla
Dealer put in addative and it worked for me (under warranty so was free)
Old Feb 9, 2007 | 03:40 PM
Vet's Avatar
Vet
Actually... how many miles on the car when you first took it out? Maybe the additive had not even been well distributed between the clutches yet. If the car had not seen much turning (such as 90 degree turns or figure 8s etc) since it was put together, perhaps this is the reason you had chatter so early. If your car had like 5 miles on it when you got it, I'd bet all you had needed to do was just run some figure 8s and it may have been ok after that... just a speculation.
When I changed the fluid and additive in my differential, the rear still chattered upon first taking it out... I then did figure 8's and put the car away... next day, chatter totally gone and has been gone ever since. The oil and additive needs to be mixed well and distributed into the clutches.
Old Feb 9, 2007 | 04:07 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
These are some of the symptoms of a Posi Traction unit. Usually you can change the oil or add some slip additive and it will go away. Changing the clutchs is not going to make a difference. There are only two ways to solve it and they both require allot of work if the oil is not doing the trick. You can have some of the carrier machined where the clutchs go in, we do this to fine tune our race clutch setup but it could also be done for a street car to help with chatter. The second is we can install a torque biasing carrier which you would never have chatter again. Both of these are very expensive options, in the end the chatter is not going to hurt anything mechanically, it is more just a issue with the driver thinking something is wrong.
Old Feb 9, 2007 | 04:47 PM
pit-pony's Avatar
pit-pony
I had a torsion diff in my Miata, never made noise.
Is this a poor design?
..jack
Old Feb 9, 2007 | 11:47 PM
Zip Corvettes
No not at all, it just has some side affects and a little chatter is one of them. You guys have felt nothing, you to see when it happens in an older Vette, you think the entire back end of the car is coming out.
Old Feb 10, 2007 | 09:45 AM
pit-pony's Avatar
pit-pony
That doesn't sound very encouraging for the long term does it, poor design I'd say.
..jack
Old Feb 10, 2007 | 12:31 PM
Zip Corvettes
Actually it is a great design, it will not hurt anything over the long haul. I actually run a full synthetic with no additive, the only chatter I get is when I back up and turn.
Old Feb 10, 2007 | 12:48 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
Thanks for that information jabbott.
I've asked several times on this board whether the chatter would actually do any harm and have never received an answer.
Like you, I get a slight amount of chatter when backing out of my garage in the morning but don't notice it otherwise. I think I'll just let it go until I take it into the dealer for something else and have them put in some additive.
Thanks again.
To Differential Chatter
