No Mufflers???
Old Feb 14, 2007 | 11:44 PM
C5nNC's Avatar
C5nNC
Default No Mufflers???
I have Magnaflow kit installed. Has anyone ever tried a system with no muffler? I was thinking of having a muffler shop fabricate the rear section of the over-the-axle part to eliminate the muffers for racing only applications. Will the lack of back pressure hurt anything besides my neighbor's ears?
Old Feb 15, 2007 | 12:55 AM
Maybesomeday312's Avatar
Maybesomeday312
I've done this on both my 06 MN6 and my 07 A6. I had a muffler shop fabricate a section to replace to stock muffler cans. Suprisingly it's not that loud. But sound is a relative thing. I haven't received complaints from neighbors or pulled over so it must be alright. It's a really deep rumble that gets higher pitched as you move through the RPM band. It didn't trip any codes and the car seems to be running just fine. The salesman I bought the cars from even loved the sound. There is some gurgle and pop on deacceleration but it sounds mean! You could always try it before spending the cash on a catback.
Old Feb 15, 2007 | 07:30 AM
rckt's Avatar
rckt
I would like to put the qtp cutouts on, 1 pipe through stock cans and 1 pipe straight out back, cut off the stock tips and put matching tips on (1 from stock and 1 from the cutout). I haven't figured out where to snake the wire for the cutout switch. I am still in the thinking stage. No rush, I have the Bullets and they sound great.
Old Feb 15, 2007 | 08:41 AM
howellrcng's Avatar
howellrcng
I did the exact thing on my 07C6A6 just a few weeks ago for $250.86 and with the stock madifold and h-pipe it sounds awesome. I did go to an aftermarket tip that has a 2 1/2 inlet like the stock exhaust, the stock tips on the mufflers are smaller than 2". I did not do any dyno tests but it at least sounds like a muscle car and performance well the 12.51 @113 speaks for itself.....yet as few little other mods but I want someone with a stock exhaust to try the intake mods and see what their car runs, I know we would alll like to know. I have had guys with over $1200 cat-backs take them off and put the same what I call red neck cat-back system on.......I love it.
Old Feb 15, 2007 | 08:47 AM
howellrcng's Avatar
howellrcng
Check this out brother.
http://forums.corvetteforum.com/show....php?t=1614215
Old Feb 15, 2007 | 10:51 AM
BADC64GO's Avatar
BADC64GO
If you are running a street class you have to have mufflers.
Old Feb 15, 2007 | 10:54 AM
Z-51 POWER's Avatar
Z-51 POWER
I would think there could be some back pressure issues???
Old Feb 15, 2007 | 11:13 AM
AU N EGL's Avatar
AU N EGL
When I put my straight pipes the reduced back pressure increased the ponies a bit. Sound is great.
Old Feb 15, 2007 | 11:45 AM
NORTY's Avatar
NORTY
Usually a "no back pressure" system will lose torque down low in the RPM band.
Old Feb 15, 2007 | 11:58 AM
AU N EGL's Avatar
AU N EGL
No back presure , correct. But reduced back pressure helps both ends of the spectrum.
1 3/4" LTs, to a 2" collector to a 3" exhuast. Unless you have a Big block or a 427 then a 1 7/8" LT header.
To No Mufflers???
