Gear whine question
Old Feb 16, 2007 | 10:43 AM
billywallstreet73's Avatar
billywallstreet73
Default Gear whine question
Ive had my 410s in for a few months now and ive noticed the past 2 weeks that the gear whine is getting kind of bad.Does this mean they werent set right? Does the whine necessarily mean my rear could go out at any time or what? The installer is not someone I would go back to,to have them re do it.I never really honestly heard it because my exhaust system is so loud and I always have the radio on.It runs fine though.
Old Feb 16, 2007 | 10:56 AM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
I have some whine with the 4.10's from 55-75 when it's not under load. Had it from day one..But it is not something that I am worried about..If you hear excessive chattering clicks from the rear, then I would have it checked..BTW have you changed the rear gear oil? I would change it if I were you ASAP..Should have been changed at 1000 miles.
Old Feb 16, 2007 | 12:14 PM
Dgatto's Avatar
Dgatto
All gears will whine, always have, always will.....no biggie
Old Feb 16, 2007 | 12:25 PM
SpinMonster's Avatar
SpinMonster
None of mine did.
Old Feb 16, 2007 | 12:48 PM
LS1LT1's Avatar
LS1LT1
4.10s (and bigger) especially tend to make a little more noise. And I agree it's likely not something to worry about, usually a little noise means that they're set up more for strength then quietness, at least that's how it's been with the F-bodies and 12 bolt rears.
Old Feb 16, 2007 | 01:14 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I've had 2 3:90 sets and neither have whined. I was strict on the 500 mile break in. Don't know if that helped or if I'm just lucky. I drag raced both sets pretty regularly in the Corvette Challenge.
Old Feb 16, 2007 | 01:21 PM
BLU-BY-U's Avatar
BLU-BY-U
if it whines under throttle and then quiets down when off throttle coasting, prepare yourself for failure.
Old Feb 17, 2007 | 08:00 PM
billywallstreet73
I guess I better change the gear oil,its been over 1k miles.The whine is only there when I take out the clutch and slow the car down.It doesnt make the noise when im on the gas at all.I had it sometimes in my mustangs with 410s,but I think this might be the loudest.The car is a beast out of the whole though!!! I certainly didnt do that mod to baby the car,so I will still beat on it the same way and see what happens.I finally got the roof fixed which was about to blow off any day,so now I can finally make it to moroso and see what she runs.Im hoping for 11'9s to 12.2s at the worst.The car has an intake,tune,kooks headers,off road x,and bullet quads with the 410s.I guess it will be up to the tires to get those times,because the car shouldnt be any slower with those mods.
Old Feb 17, 2007 | 08:50 PM
welcome2try
St. Jude Donor '08
I followed the 500 mile break in with a few spirited bursts, I only hear a slight whine on deceleration between 75-55, not when I gas it. I think it's the tranny whinning. So far no problem...Just change the oil..Good luck at Moroso, and keep us posted on track numbers.. Oh by the way, when you change the diffrential fluid, change the tranny fluid to royal purple much better shifts and you retain factory warranty on the tranny..
Old Feb 17, 2007 | 09:37 PM
dennis50nj's Avatar
dennis50nj
i have ran 456 488 and 513 never heard a sound if it makes noise it was set wrong
Old Feb 17, 2007 | 09:57 PM
VET4LES's Avatar
VET4LES
A whine does not sound right. The only time I have ever had a whine, the differential went out.
Old Feb 17, 2007 | 10:20 PM
Byrdguy's Avatar
Byrdguy
If it whines, the gear lash wasn't set properly. You won't necessarily get a "failure", but the whine will continually get louder. run it until you can't stand it then have a good mechanic put new ones in it. Once it has started to wear, there is no resetting of the lash to fix it. fluid change won't help. I had a 55 Chevy years ago and had 4:11s in it that weren't set up right, after running it until it got really loud, I tore it down and the pinion gear teeth were so sharp you could shave with them. (they start out pretty blunt). Good Luck.
Old Jul 27, 2019 | 08:51 PM
JJ from Canada's Avatar
JJ from Canada
7th Gear
What is involved in setting the gear lash? Does the rear end have to come out or can it be set (adjusted) in place, with the cover off??
Old Jul 28, 2019 | 09:08 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
It cannot be set while in the car. And chances are the gears have been damaged from not being set up properly or properly broken in. Will have to replace to eliminate noise.
To Gear whine question
