Starting on Jack Stands????
Old Feb 22, 2007 | 11:09 PM
MYZED06_EH's Avatar
MYZED06_EH
Default Starting on Jack Stands????
Is it advisable(safe) to start a car while it is supported by four jack stands or could this result in disaster?
Would revving it possibly make it unstable?
Thanks for the input.
Old Feb 22, 2007 | 11:13 PM
MYZED06_EH's Avatar
MYZED06_EH
I guess it doesn't really matter, C5 or C6, but I was supposed to post in C5 section. Sorry.
Old Feb 22, 2007 | 11:26 PM
Mike V.'s Avatar
Mike V.
Default Running car
I have done it w/o any problems. I guess it comes down to how risk adverse you are. When I installed my new exhaust I ran the car & checked for leaks & revved it to check out sound. Then again, I don't wear seat belts & wear a non- DOT approved helmet when I ride my bike. If your really worried get ramps, you can even use four. Drive up the first set, chalk tires, jack up opposite end place ramps under tires. Definately not going anywhere.
Old Feb 22, 2007 | 11:27 PM
calemasters's Avatar
calemasters
If the car is stable and you support the rear lower control arms to keep drive axles horizontial and do not rev engine you should be OK. I would not get under the car.
Old Feb 23, 2007 | 12:15 AM
2LT-Z51's Avatar
2LT-Z51
when i block up my car like that it is a little to unstable for me...
(probably OK though - I'm kind of extreme - **** is probably a better word)
i would put the stands on the frame rails.... (in the oval holes) if you plan to rev the motor and let the wheels turn....
Old Feb 23, 2007 | 12:34 AM
F1_SS's Avatar
F1_SS
1. Yes its ok AS LONG AS THE CAR IS STABLE.
2. Why did you put wood between the jack stands and the rear end support? Thats what its designed for.
3. You do know that for the 3 thing involved with it being on jackstands the wood is the most likely to fail. Just my .02. Would hate for you to get home and something nasty happen to your car.
4. Why did you put wood under the tires? You know they make mats for that right?
Old Feb 23, 2007 | 01:23 AM
codename Bil Doe's Avatar
codename Bil Doe
The jack stands were causing the wood to fail. You're kidding, right?
Old Feb 23, 2007 | 01:33 AM
MYZED06_EH's Avatar
MYZED06_EH
Check this link out. That is what I went by. The wood under the tires is to raise the car high enough to get a jack under it.
http://www.z06vette.com/diy_lift.php
To Starting on Jack Stands????
