"Coolant Low" - DEX-COOL
Old Feb 23, 2007 | 11:32 AM
vette-oholic's Avatar
vette-oholic
Default "Coolant Low" - DEX-COOL
Got this DIC message last nite. The users manual says to only use DEX-COOL. has anyone used anything else? I ended up just putting about 12 oz of water in and it was enough to clear the message. I guess i will have to pick up this DEX-COOL stuff. is it available all over?
Old Feb 23, 2007 | 11:43 AM
Miaugi's Avatar
Miaugi
Many retailers sell Dex-Cool compatible, I'm not picky for my regular daily drivers but I have always just bought it at a dealer when I needed some for the Vette(s).
Old Feb 23, 2007 | 12:24 PM
dbradley's Avatar
dbradley
Available everywhere. Just don't mix in the "green" stuff.
Old Feb 23, 2007 | 12:32 PM
rfopt's Avatar
rfopt
Was your coolant level in the coolant recovery tank very low, below the minimun level?
Old Feb 23, 2007 | 12:36 PM
C7cmnthru's Avatar
C7cmnthru
IMO - the more important issue is why you got the message. My $.02
Old Feb 23, 2007 | 01:07 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
When it say only use dexcool, it means don't use the green stuff. They are not compatible, and a cooling system should never be switched over from one to the other. But you still mix dexcool with water. Like the green stuff, the ratio is up to you. I don't have to worry about freezing, so I have been using 1/3 dexcool, 2/3 water.
And like already mentioned, you can find it almost anywhere.
Old Feb 23, 2007 | 03:30 PM
stabori's Avatar
stabori
St. Jude Donor '08
Big question is where ur coolant went
Old Feb 23, 2007 | 03:54 PM
vette-oholic
well i have 14k miles and have never had to add any coolant or get a message before. I couldnt see the line so i figured i would just pour the bottle of water i had into it (about 12 oz) and the error went away, so it looks like it was a tiny tiny drop low. Then i drove the car about 10 miles and the temp gauge stayed normal.
is it that abnormal to burn a little off? I believe the manual says if u need to add collant more than 3-4 times a year, then theres a problem.
when i get out of work , I will check what level its at.
thoughts?
Old Feb 23, 2007 | 04:25 PM
stabori's Avatar
stabori
St. Jude Donor '08
Thats a good question. I dont know how much evap is normal. I havent added any in 2 years but u might be in a much warmer climate or track the car. Oops, we are in the same state. U been doing many of those miles 1/4 at a time at Englishtown ?
Old Feb 23, 2007 | 04:32 PM
Miaugi's Avatar
Miaugi
....is it that abnormal to burn a little off? I believe the manual says if u need to add collant more than 3-4 times a year, then theres a problem.
thoughts?
Good point by 04cmnthru & stabori. Basically the cooling system is a sealed system, well not totally sealed, but close, so there could be some lose considered normal. If your car was marginal to begin with, that may explain it, or if your fill cap was loose or defective could also do it. I would consider that having to add more water/coolant more than once a year abnormal.
Perhaps the best advice for now would be to check the level and all the connections for signs of any leaks and then keep and eye on it, especially with the warmer summer weather not too far off.
Old Feb 23, 2007 | 04:41 PM
vette-oholic
ive made 2 passes atco, but i drive the car hard at times.
about where do u live?
vette-oholic
Old Feb 23, 2007 | 05:41 PM
C7cmnthru's Avatar
C7cmnthru
As Miaugi noted, cooling system is a closed system. It may have come low from the factory, so watch it. If you keep losing it there is a leak somewhere. You might want to look around under the car for discoloration/crystalization - might be the sign of a coolant leak. Or better yet, take it to the dealer to check it out. That way if they find nothing you have established a service record in case there is a problem that went undetected. BTW- you do not just mix coolant with water at whatever mixture ration you think is right - the service manual will telll you what is right for your car. Coolant pH is critical in aluminum systems and can influence the myriad of sensors that rely on proper coolant mixture/temp. Also, mixing at the incorrect ratios can contribute to internal corrision.
Old Feb 23, 2007 | 06:01 PM
stabori's Avatar
stabori
St. Jude Donor '08
I live about 15 minutes from Englishtown. I go and watch. This year I will make some runs.
Old Feb 23, 2007 | 06:16 PM
CessnaDriver's Avatar
CessnaDriver
FYI
I believe there is no coolant sensor to speak of and determines low coolant by using temperature monitoring methods.
Anyone know the details?
Old Feb 23, 2007 | 06:56 PM
mlongo99's Avatar
mlongo99
The service manual also tells people that live in Alaska to use the same water mixture and oil viscosities as people in the desert. Yes, there is a minimum level needed for corrosion protection, but some people also need a lot more freezing protection than others. 50/50 is not a magical combination, but it works well, and is a nice even number to reccomend. Also, there are corrosion inhibitors that are known to work well that are available as additives.
Old Feb 23, 2007 | 06:58 PM
mlongo99's Avatar
mlongo99
Originally Posted by CessnaDriver
FYI
That's right. I now recall reading that in the service manual. There was quite a bit written on how it works.
To "Coolant Low" - DEX-COOL
Old Feb 23, 2007 | 08:10 PM
C7cmnthru's Avatar
C7cmnthru
http://www.imcool.com/articles/antif...l-macs2001.htm
For those of you interested in the proper mix ratio, please see bullets 5 and 6 of the article.
Old Feb 23, 2007 | 09:27 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
AFAIK, Dexcool is Dexcool. But you've got to be careful with some brands like Toyota, they make two orange/pink coolants that are hard to tell apart unless you have them side by side.
Old Feb 23, 2007 | 09:34 PM
aseipos's Avatar
aseipos
I had one of these "low coolant" incidents and responded by picking up a couple gallons of distilled water so I could get home and check it properly.
Turned out that I was only a few ounces low, if low at all. The no-float, non-mechanical way our cars has of monitoring coolant level also means that the "low coolant" warning can sometimes be wrong, especially if we don't warm up the car sufficiently before taking off. Starting in a warm garage, I usually allow a minute or two of warmup before taking off. That particular morning when I got the "low coolant" warning, I drove off after only about a 10 second warmup. False alarm.
