Fast Intake or Porting TB
I personally think a ported TB is good for nothing.
, cheaper, but useless. HP costs $$$$, pure and simple.If you decide to get a FAST and paint, here's the steps:
1) remove the gray top half of the intake using a hex wrench(allen)
2) Mask off any and all openings and gaskets if applicable,with blue painter's tape
3)sand with 400 grit and then make sure all sanding residue is gone, wipe down to clean.
4) once area is clean and dry, apply dupicolor primer gray evenly over intire area, start with a misting instead of going heavy off the bat, allow dry time.
5)Use universal flat black(duplicolor) and again, apply in a misting manner for the first application, then go heavier.
6)allow dry time, remove tape and you're done except for re-assembly....make sure those gaskets are lined up and have a good seal.
When getting paint, I got the duplicolor for plastic automoble parts. Others have suggested engine paint, but since the FAST isn't heat sink, the plastic paint is good and has a flex additive , so it's less likely to flake or scratch off, like plastic painted with engine enamel.
Good luck!!
Good luck!!
I'm thinking of having Cory do my stock intake too, it seems like an easy mod that would probably deliver reasonable bang for the buck. But I think that the claims I've read on CF of it giving any kind of increased gas mileage are dubious.
There's a lot of FAST vs Ported Stock Intake threads and comments out there. There is really no comparison. The FAST obviously outperforms the ported stock intake. Its been proven over and over again. You've got to look at it like this... What are you looking to gain and at what cost?
Ported Stock Intake Manifold
+ Average gain of 10rwhp and 11-15 rwtq over stock unported
+ Complete stock external appearance
+ No mods to the car to make it fit
+ No possible dealership hassle
$ 50% of the gains for about 25% of the cost of the FAST as installed on a LS2 Corvette
+ Is a direct bolt-on that can be installed by anyone who owns metric sockets, screw drivers, pliers, and has internet access.
FAST Intake
+++++ Average of 15 to 17 rwhp gain if you just bolt it on.
- Does not appear stock unless you grind the name off and paint it black. The dealership service dept will still notice it if they have a clue at all.
- Requires install kits to make it fit the LS2 Vette
*Firewall/wiper tray cut and patch with dyno mat or the LPE patch kit.
*Also requires the fuel rail adapter kit
*Also requires the MAP wiring harness to either be rerouted to the back of the manifold or adapted to the front.
$$$ Cost at least $725 for the manifold alone, not including the needed adapter kits. Expect to pay at least $825 minimum with the required adapters.
Ported FAST
++++ Is advertised as up to 25 rwhp gain.
$$$$ Adds between $200 and $500 to the cost of the FAST and required adapters.
So... you see there is really no good comparison. They are not equal or even close. Each has benefits and costs associated. It all really comes down to your individual concerns as far as performance level desired, budget, and potential concerns over warranty.
If you're going all out for max HP - the Ported FAST is the way to go.
If you are looking for nice gains, minimal hassle, and not to break your budget- get the ported stock intake.
FAST Intake
Ported FAST
FAST Intake
Ported FAST
A stock car with a ported stock tb and no tuning?
