Melrose headers??
Old Feb 27, 2007 | 08:25 PM
PaulC6Z's Avatar
PaulC6Z
Default Melrose headers??
What do you guys know about them?
Old Feb 27, 2007 | 08:44 PM
Rphvette's Avatar
Rphvette
Get them! I loved them. PLus tthey are coated. I have them with x pipe and Random tech high flow cats with Magnaflows Axle-back mufflers. Perfect combo. Not obnoxois loud and not soft. Nice hum at idle and highway speed, but when you punch it it get loud enough to let others know you got something. And if you do head and cam with it like I did, oh boy, it's even better. I absolutely love it. If you can hear my car in person, you will be sold. Got many compliments with it.
Bruce
Old Feb 27, 2007 | 09:40 PM
Radical05's Avatar
Radical05
They are great quality, perfect fit and coated so wont decay, change color, heat goes away fast and did I say they were great. I got them on over a year ago and no issues. I have coated headers in another car for well over 10 years now and still look great. I just like the smooth design and high quality and was one of the first and biggest supporters of them. You will not be disappointed and the customer service is A1.
Old Feb 27, 2007 | 09:54 PM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
I've got them with GHLs. Great sound, quality and fit.
GM
Old Feb 28, 2007 | 02:44 PM
Lipps C5's Avatar
Lipps C5
I would go with 304 Stainless steel headers over Melrose Mild Steel Headers.
Old Feb 28, 2007 | 04:15 PM
Wingrider's Avatar
Wingrider
What he said. I really like mine.
Old Feb 28, 2007 | 04:25 PM
classicfit's Avatar
classicfit
Wingrider;
read my post from yesterday entitled "Headers Installed (link to photos)" right below your post. I installed Melrose, love them and the pics show what they look like from under the car.
Old Feb 28, 2007 | 04:27 PM
classicfit's Avatar
classicfit
Sorry, I should have addressed the above to Deuce Bigelow. my bad.
Old Feb 28, 2007 | 10:38 PM
PaulC6Z's Avatar
PaulC6Z
Thank you guys. You make this site a real treat to log on to. Here is one to ya' all
Old Mar 1, 2007 | 09:51 AM
BADC64GO's Avatar
BADC64GO
Old Mar 1, 2007 | 10:31 AM
tjwong's Avatar
tjwong
The Melrose headers are of excellent quality and fit. Stainless steel headers has no real advantage to a coated mild steel header. Just because they are resistant to corrosion SS has other qualities that actually can make them undesirable as headers. For one the 304 alloy will work hardened in time due to the constant heat and cooling cycles, this make the metal brittle. How many busted AIR tubes have you guys heard about these days in the C5 line up? Welds at the collector areas will also crack due to this same phenomenon. While 304 is a better alloy as far as corrosion resistance goes, a cheaper and uglier 409 alloy is much better suited for exhaust use and is much less prone to embrittlement. For that matter if you want pretty you can coat the 304 headers as well.
Old Mar 1, 2007 | 01:55 PM
Fore58's Avatar
Fore58
I've heard good things about Melrose fit etc. but haven't heard too much about results. Anyone?
Old Mar 1, 2007 | 02:30 PM
BLWright's Avatar
BLWright
Melrose Headers, no cats, Bullets, Halltech, and a tune netted my '06 coupe a 45/35 gain.
They are a great design and the smooth flow primaries work very well. I was concerned at first with the no-flange design at the collector, but have had no problems and zero leaks for the system as a whole. You will not be disapointed with the purchase.
Old Mar 1, 2007 | 02:32 PM
BLWright's Avatar
BLWright
The Melrose website shows dyno graphs.
http://www.melroseheaders.com/dyno_results.php
Old Mar 4, 2007 | 02:03 AM
longboy4's Avatar
longboy4
......I put the Mels on my car. The coated finish is the way to go. You don't see street rods with raw headers hanging on their showpiece motors. The less expensive stainless look like crap and perform well, will not hold the heat from radiating to other underhood and chassie components. In my case, the sateen finish of coated pipes was a selling point.
To Melrose headers??
