Z06 Calipers , bolt torque?
Old Feb 28, 2007 | 05:49 PM
speedneed's Avatar
speedneed
Default Z06 Calipers , bolt torque?
Installing pads on the Z06, what is the torque for the two main bolts? 125? I'm assuming it would be the same front and rear. What about the center bolts? I'm not going that route but was wondering as I have new ones I could use.
Old Feb 28, 2007 | 09:23 PM
VET4LES's Avatar
VET4LES
Have you tried the Z06 section?
The C6 is as follows: Brake caliper guide pin bolt = 23 lb ft
The front and rear bracket bolts = 125 lb ft
Good luck.
