What dyno gains can are expected from the LG Longtubes. I have a C6 with the paddle shifter. I would be interested in the before and after numbers if people have them.
06 A6 (paddle shifter): Before: 334 rwhp 321 rwtq, after LG's and 160 stat: 360 rwhp 360 rwtq
Picked mine up from LG today and I love the results. I'm at 370hp in an A6 with the LG Pro long tubes, a Halltech CAI and a tune. It really wakes the car up! They installed everything and had it ready to go in 6 hours.
Forgot to add I was at 343hp before the goodies per the pre-install pull. I'm at 6500 miles and I think that contributes to the decent stock number. The torque curve after the install is awesome as it pulls better at every rpm range.
I installed a mild cam when I did mine in my 06 A6, stock was 337rwhp, after mods was 406.5, have installed a FAST intake, now up to 422.1, no ill effects on the tranny.Also running the headers and cats through stock exhaust.
anyone get a gas smell when driving around? I had dynatech headers on my C5 and everytime I got out to go to work, people could smell a gas/exhaust smell on me. We checked for leaks many times, but came up empty. Want the power of the LG's on my magnacharged C6, but cant go smelling like a$$ as a financial advisor meeting with clients.
Thomas
Tampa, Fl
Thomas
Tampa, Fl
Must have been running rich. Did you have it tuned?
sure did. some of the 02 sensors had burned out in the back when the wire was laying on the headers. We ended up cutting them out, but im not sure if it burned out the cats when it overheated 1 bank of them...Pipe became rainbow colored on that side.
I want to do headers, but can't smell like exhaust when working, which is what I am trying to figure out.
I'm thinking of doing LG headers too, for me its all about torque, but I've got some concerns. After putting headers on both my Duster 340 and Challanger T/A back in 1973 I swore I would never ruin perfectly good cars like that again. The things always smelled, pinged, rusted, rubbed against stuff and I honestly felt no difference. I'm easily seduced by power however, and I hear so much good stuff about the 'new generation' of headers that I'm willing to unlearn that lesson. My concerns with the new headers are I hear things about various brands not fitting right (ARH), and leaking through the joints (LG). Am I worried for nothing?
From: YOU SEE ... I'M NOT CRAZY ...I'M JUST AHEAD OF THE CURVE
St. Jude Donor '09-'10
Header construction is much different now from then ... I am not a Mopar guy, but I do know many stock exhaust systems back in the day were as good or superior to aftermarket stuff as well.
I have LG on mine. Get em coated (inside and out) and as long as they are put on correctly you will have no problems ... and you will love em!
I have these on my C-6 LPE 403 stroker track car and on my modified c-6 z-06 they are the best headers out there w/ the best torque gains and HP. Great guys to work with to.
Yes, I think that you are worried for nothing. I'd stick with the top brands though. KOOKS, LGM, ARH, Stainless Works.
I know first hand that the LGs install easily and are a quality piece. So are the American Racing headerss I am told, though I have heard of a couple of people having to remove their starters to install the American Racing headers. No big deal even if that is the case.
Headers will give you the low hanging fruit, the easy 25-30RWHP horsepower and more torque. For this, the LG Pros are hard to beat. A cold air intake and a tune to go along with them should put you around 380 at the rear wheels.
As far as rusting, I would stick with 304 stainless as opposed to mild steel to avoid corrosion and some consider coating, be they 304 stainless or mild steel.
Smelling is not a problem if you are running catalytic converters. Nor is pinging if the car is tuned well.
Jim,
I know exactly how you feel. I had Cyclone headers on my 1968 Firebird 400 back in 1970 and I hated them. I crushed them twice because they hung so low, and I probably blew out at least a dozen header gaskets because I couldn't keep the bolts tight. At least they didn't rust out because I lived in Arizona.
I got back into it with my 94 Z28. I put on a set of mid length MAC headers that I had Jet Hot coated. They worked great, but I refused to get long tubes because of my bad memory of crushing the ones on my old 68. Finally I put a good set of Stainlessworks long tubes on my 01 Z28 and they tucked up so well I never even scraped them.
You can't go wrong with LG's, Kooks, or AMR's for the Vette. It's a very easy install (I have the LG Pros) and they tuck up so well I never scrape them. Plus, you really don't need to coat the stainless, they look good without coatings, won't rust, and already have a very low thermal conductivity.
Go for it! You won't regret it, it's the best mod I've done to my Vette.
On dyno my Z06 I actually lost a few peak HP (LG Pro). I did a retune, and picked it back up. Similar experience with others, do not know about any other motors than LS7, sorry. However there is a significant "shift to the left" of power curves. Thus the area under the dyno curves is increased. The "feel" difference is quite significant, and noticible, enough to say it is a necessary upgrade. If you are going to NASA 3/31 at VIR, I'll be glad to show you.
