tire pressure sensor redux
I purchased another set of C6 rims with new TPS's. I mounted these to see what would happen if I didn't use a reset tool to match them to the car. I wanted to know if I could still access Competition Mode. I understand that the sensors do not register until the car reaches 25 MPH. Before starting, the reading from when the original rims were mounted was 30 PSI all around. After driving some distance, the readings showed 29 PSI and I had no warnings about low or no tire pressure. This reading did not change throughout the drive even though the tires typically gain 1-2 PSI in this weather. So, while the new sensors are obviously not sending accurate data to the car, the car believes that the sensors are sending data. What's going on?
According to the manual the car will go "approximately 1 hour" (that's steady driving without turning off the engine) before you'll get a "Service Tire Monitor" alert.
If you want to try something else, try this - run 2 tires (say, your front tires) with sensors that are registered, and 2 other tires that are not registered. I think that shortly after leaving your garage area you will get some DIC lights and messages. I think the car is more tolerant of zero sensors than it is of a couple of good ones and a couple of bad ones. It won't wait "approximately 1 hour" to give you alerts because it is getting info from a couple of sensors and knows it should be getting info from all of them, but isn't, so it tells you that you've got a sensor problem right away.
If you try that and that's what happens (that's what happened to me), I think it pretty well proves that the car is getting no info at all from any sensor that is not registered.
Bob
I have a lift in the garage. On it, I have a Ford Ranger. The registered wheels are in the bed of the truck. I park the Vette under this. I don't know where the TPS receiver is located but there is a good bit of metal between where the wheels are and where the receiver, at it's closest point, might be. Can the wheel sensors actually transmit data that far? Could this account for the reading of 29 I got on all four the next morning?
If it takes an hour for the sensors to "reset" then I've got it made. Autocrosses, at best, consist of 5 35-45 second runs - nowhere near an hour. I should be OK w/o the reset tool... This still puzzles me though.
It sounds like you'll be fine Auto-Xing with no sensors (or no tool).
Yeah, this is a screwy system we have to deal with!!!
Bob
