364 to 408
Old Mar 8, 2007 | 10:03 PM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
Default 364 to 408
What is needed to turn a 6 liter to a 408?
GM
Old Mar 9, 2007 | 09:48 AM
calemasters's Avatar
calemasters
This will get you close:
I know, that's not what you were asking.
Old Mar 9, 2007 | 11:49 AM
AintQik's Avatar
AintQik
403 is a 4" crank and a set of rods. I pretty sure you need to re-sleave an LS2 to go bigger. 408s are usually the iron blocks punched out with the crank and rods. So, if you are going to go through the trouble of sleaving it, go 427.
Old Mar 9, 2007 | 12:21 PM
SpinMonster's Avatar
SpinMonster
New pistons too. You cant reuse the old ones with the new rods. RJ are we hanging out this weekend? Things are tight for me but I can be down there for a late hangout by 7 or 8. I can tolerate you for 5 hours or so.
I do have your new PBA card.
Old Mar 9, 2007 | 12:27 PM
AintQik's Avatar
AintQik
Whatever works for you man. We can shoot for next weekend. Need your addy have to send you something. Oh yeah I forgot to mention the pistons. Course you need those too.
Old Mar 9, 2007 | 01:02 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Mar 9, 2007 | 02:58 PM
EuroRod's Avatar
EuroRod
She's real fine ........................
Old Mar 9, 2007 | 04:30 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
Beat me to it!
Old Mar 9, 2007 | 08:40 PM
TTRotary's Avatar
TTRotary
How much does a 402 cost? Is it cheaper to mod my engine, or just buy an assembled 402 bottom end? This would be for non-FI.
Old Mar 9, 2007 | 10:36 PM
johnodrake's Avatar
johnodrake
Moderator
Lingenfelter 403 built short block runs $4495
http://www.lingenfelter.com/Merchant2/merchant.mvc?
Old Mar 9, 2007 | 10:59 PM
valdeztke's Avatar
valdeztke
GM
Well since no one else pulled it - SEARCH IS YOUR FRIEND
You planning on building the motor up yourself?
Old Mar 9, 2007 | 11:55 PM
Shrike6's Avatar
Shrike6
Somba master
You ought to know my limitations re: mechanical assembly/ disassembly.
GM
Old Mar 10, 2007 | 08:05 AM
valdeztke's Avatar
valdeztke
GM
True
Old Mar 10, 2007 | 08:17 AM
Max@Cartek's Avatar
Max@Cartek
If you choose to re-sleeve then I would go 427 all the way. Nothing like 9 second power NA.
To 364 to 408
