C6 brake fluid capacity
Old Mar 10, 2007 | 07:51 AM
Lee HB's Avatar
Lee HB
8th Gear
Default C6 brake fluid capacity
Anyone know how much brake fluid needed for flush on C6 Z51?
Dealership and Helms manual don't list. Thanks!
Old Mar 10, 2007 | 04:39 PM
AU N EGL's Avatar
AU N EGL
To flush use one full liter. Then another liter to fill.
SO buy two new DOT 4 bottles.
Old Mar 10, 2007 | 05:22 PM
DZeckhausen's Avatar
DZeckhausen
The entire system holds less than 1/2 liter. So a single 1 liter can of good quality DOT 4 fluid (ATE TYP200, Valvoline SynPower DOT 4, etc.) is plenty for a brake fluid flush. If you're planning to track the car, something like Motul RBF600 is more appropriate. The Motul comes in 1/2 liter bottles.
If you're installing stainless steel braided brake lines or a big brake kit and/or you don't have much experience bleeding brakes, you may want to have a second can of fluid on hand. But you probably won't even open it. I've installed a 4-wheel big brake kit using only a single 1/2 liter bottle of Motul RBF600 racing brake fluid. It was close and, admittedly, I was going for a record. But I was able to complete the job and bleed to a rock hard pedal with only that one bottle.
Here's a link to some bleeding instructions I wrote that include some tips for getting an extra firm pedal. For example, I describe tapping on the caliper body with a rubber mallet to cause any trapped bubbles to break free and float to the top, where they will be expelled through the bleed screw. Instructions for Bleeding Brakes
Old Mar 10, 2007 | 06:58 PM
outnumbered's Avatar
outnumbered
It took about 2 1/2 bottles of Motul to do mine the first time. Actually closer to 3. The right rear brake line was full of air, yes from the factory.
It took a bit more to get the air out.
I like the small bottles. There is less waist. It is said it is not good to use an open bottle later. Moisture can get in the fluid.
Old Mar 10, 2007 | 07:42 PM
DZeckhausen
I'm constantly amazed by how much air is left in the brake system by the factory. You can often transform the pedal feel by doing a good, competition bleed on your brand new Corvette, BMW, etc.
The bleeding technique has a lot to do with how much fluid it takes to get all the air out. If you use a pressure bleeder or a vacuum bleeder, it will take far more fluid. However, with the traditional 2-person bleed technique, you can use far less fluid. With an assistant pressing down HARD on the brake pedal, you should suddenly crack open the bleed screw, then close it as your assistant's foot reaches the floor. This sudden jolt to the brake fluid will knock loose bubbles and get them out fast. You should be able to do each corner in as few as 7 or 8 pumps of the pedal. If you hook up a pressure bleeder and crank it up to 20-25 psi (much more will blow the reservoir off the master cylinder and make a huge mess!), the brake fluid will slowly flow out the bleed screws and the bubbles will take their sweet time exiting the system. Similarly, a vacuum type system sucks (no pun intended) at getting air out quickly. Either method can easily use up two or more 1/2 liter bottles of Motul.
There's no harm in using extra brake fluid and, if your technique results in air bubbles still coming out after a liter or more of fluid has gone through the system, by all means keep going. I always make sure I do at least three more pumps of the pedal at each corner, after I've seen the last bubble come out.
outnumbered is absolutely correct. If there's any extra brake fluid left over in your bottle after bleeding, mark the date with a Sharpie pen and throw it out after a week or two. Brake fluid is hygroscopic and will quickly absorb moisture from the air.
Old Mar 10, 2007 | 08:02 PM
outnumbered
It's interesting that you mentioned the power bleeder. I did in fact use the motive bleeder. It worked extremely well. However I only used 12 psi as the manufacture suggested.
I am under the impression that you need the power bleeder to get the fluid through the ABS System module??....
Either way, the power bleeder worked well. Between HPDE's we do a two person bleed the old fashion way in order to freshen up the fluid in the calipers, which gets pretty dark from hard use.
By the way, AU N EGL was instrumental in giving me pointers of brakes and maintenance. Plus a bunch of Internet research.
Old Mar 10, 2007 | 08:46 PM
DZeckhausen
The ABS/stability control module is out of the circuit when you are bleeding the brakes. There are isolation and dump valves that are normally closed when the ignition is off and/or ABS is not cycling. That's why you need a special ABS scan tool to cycle the valves and activate the accumulator pump when bleeding the ABS unit. This is only necessary when replacing the ABS control unit or if you somehow managed to get air into it.
The Motive pressure bleeder does nothing functionally different to the brake system than an assistant pushing on the brake pedal, other than producing far less pressure. The ABS control unit and the calipers are downstream of the master cylinder and reservoir. There are no alternative flow paths. Just two input lines (front & rear) leading from the master cylinder to the ABS control unit, and four output lines, one leading to each caliper from the ABS control unit. The ABS control unit can not tell the difference between pressurizing the system with 12psi using the Motive bleeder or a person very gently pressing on the brake pedal.
I attended two classes on ABS and stability control system design, taught by James Walker Jr. At the time, he was the head of Vehicle Performance Development at Delphi and the leader of the design team on the Corvette C6 ABS and stability control systems. Now he's moved on to a private company that does accident investigations and is like a CSI for cars. He still teaches classes for the SAE and I highly recommend this one: Introduction to Brake Control Systems: ABS, TCS, and ESC . Or, for much less of a personal investment, you can check out his excellent new book: High Performance Brake Systems
Old Mar 11, 2007 | 07:06 AM
outnumbered
Great info.
So basically in time the fluid in the Abs will mix with the new fluid. After flush/bleeding multiple times, will the dot 3 be diluted with the dot4?
I guess this is another good reason to make sure you use fluids compatible with dot 3.
Old Mar 11, 2007 | 09:34 AM
AU N EGL's Avatar
AU N EGL
Great info.
That is why a full liter is suggested to flush the brake lines. To get all the old DOT 3 fluid or any old fluid out of the ABS moduals in the calipers and the brake lines. 1/2 liter just does not do this.
OR when the ATE fluids are used, One is Blue and the Other is Gold, but the fluids are identical. This way there is the color difference between the two fluids, and it is easy to tell when the old fluid is fully flushed.
Or just keep a close eye on the fluid color change, from dirty to clear.
I prefer the power bleeder method and use the peddle pump only to set the brake pads and brake ride height.
Old Mar 11, 2007 | 10:02 AM
outnumbered
I wish the other brands had different colors.
Hey Tom, Do you put fluid in the Motive tank or do you just use it for pressure and keep an eye on the reservoir. The tank and hose need to be cleaned afterwards.
Old Mar 11, 2007 | 10:18 AM
AU N EGL's Avatar
AU N EGL
No, I just keep an eye on the reservoir. Putt fluid into the reservoir after two claipers have been bleed.
Rember for track events dont fill the reservoir much over the 1/2 point. HOT brake fluid expands. If the reservoir is filled up, where will that HOT brake fluid expand too??
Also not a bad Idea to Zip tie a rag over the MC Cap for just that overflow reason.
When I change or bleed my brake fluid, I can tell the color difference. Dark to black changed to Clear Golden colors. Easy to spot.
Old Mar 11, 2007 | 10:21 AM
DZeckhausen
That doesn't make sense. Since the ABS module is isolated by normally closed solenoid controlled valves, it wouldn't make a difference if you flushed 100 liters of fluid through the system using your pressure bleeder or the manual method. The tiny amount of fluid trapped in the ABS accumulator (about 5cc) will only be purged if you cycle the ABS with a scan tool while bleeding. Alternatively, you could bleed the brakes, then drive the car, then bleed the brakes again. Each time the car is started and then driven above a certain speed (typically only a few miles per hour), the ABS cycles through a self-test mode and the fluid trapped in the control module is mixed with the rest of the fluid. But the amount of fluid is so minute that it really makes no difference. It's like the tiny amount of engine oil that remains each time you drain and replace it.
If you're changing types of brake fluid from normal DOT 4 to something exotic like Castrol SRF, where there may be compatibility issues, then you probably want to use the scan tool to cycle the ABS while bleeding or else you want to bleed the car twice, with a short drive in between. But for your normal bi-annual maintenance flushes or your bleeding between track events, the normal method is perfectly fine. The amount of trapped fluid is insignificant.
The ATE TYP200 and Super Blue Racing combination is merely a gimmick designed to make you use more brake fluid than necessary. I can tell you from experience, it takes lots more fluid to get all the blue dye out going from blue to amber than it does going in the other direction. It takes just a tiny amount of blue dye to turn the entire system dark. You can easily use three liters before the exiting fluid turns from dark blue to light blue and finally runs clear.
Also, Super Blue Racing is not a DOT 4 fluid. It has DOT 4 performance, but the dye violates the DOT 4 specification's color requirement of clear to amber. If you carefully compare the wording on the two cans, you'll see that TYP 200 says "This DOT 4 motor vehicle brake fluid conforms to ...", while the Super Blue Racing can has the weasel wording: "Better than specifications of FMVSS No 116 DOT 4/DOT 3 (differing blue coloration)...".
Finally, the blue dye will, after extended use, stain your reservoir blue to the point where you can't see through it any longer to determine brake fluid level.
That's always a good idea. And it's one reason I dislike the "SpeedBleeder" method, which uses 1-way valves in place of bleed screws to allow a single person to pump the brake pedal, while the catch bottle is left unattended in the wheel well. With nobody watching, you can't tell when the fluid is running clear. You also can't tell if your plastic hosing has popped off the bleed screw and, with each pump of the pedal, you're spraying caustic brake fluid onto the side of your car. Finally, it shares the same problem as power bleeding and vacuum bleeding. You never get enough pressure exerted on the brake fluid to knock loose those last few stubborn air bubbles.
If only the manual method can affect the brake ride height, doesn't that tell you that the power bleeder method isn't getting all the air out?
Old Mar 11, 2007 | 10:49 AM
outnumbered
I used the power bleeder to get the air out that GM left for me to dispose of. I have bled the brakes since then the old fashion way about 6 times and not one air bubble.
Old Mar 11, 2007 | 12:33 PM
AU N EGL's Avatar
AU N EGL
No the peddle use in my case is to set the brake pads. When I bleed brakes for the post part I have pushed the pistion all the way in and changed the brake pads at the same time.
The power bleeder does a great job and I believe better then the peddle pump method. But if you dont have one, the other works just as good.
If you only wish to push a few cc's though the ABS moduel be my guest. I prefer to make sure by flushing a fair amount though. There has been more then one time I have flushed someones brakes only to notice the fluid going from black, to clear, back to black or mix again. Then back to clear. Rember once a bottle is open it can not be saved, so use it up.
I use Castrol SRF at $72-75 / liter. My life depends on my brakes. and I beat the living chit out of them.
Never had to use a scan tool with the power bleeder method.
I dont like the so called speed bleeders nor the vacum pump method. Personally my speed bleeder is, the power bleeder with 12-15 psi, a 10 mm open ended wrentch, with clear tygon tube attached to the bleed head and draining into a clear 16 oz soda bottle with the top drilled to run the tygon tube though.
Old Mar 11, 2007 | 12:41 PM
DZeckhausen
You're not hearing me. The ABS module is completely bypassed when the car is turned off, unless you are using a scan tool to cycle the solenoid valves. You can not replace any of the fluid inside the ABS module by pressure bleeding, vacuum bleeding, or via the pedal pump method no matter how much fluid you use. It's out of the circuit.
Here's a quote from page 66 of James Walker's new book, "High Performance Brake Systems". Remember, James was in charge of the team that designed the ABS and stability control on the Corvette C6.
"There are a number of high-tech tools available to bleed brake systems, but nothing beats a good old manual bleed for bonding with your vehicle. Plus, while alternative techniques may save some time in the process, the quality of a manual bleed is second to none."
Old Mar 11, 2007 | 01:40 PM
AU N EGL's Avatar
AU N EGL
David I am. are you reading that last section in blue you posted??
Manual bleeding ?? Pressure Bleeding ?? one in the same. If some one needs to turn the KEY to accessor and let the "ABS Warm Up' light cycle so be it.
and Yes I have meet James and many many Corvette engineers. They come to MY ( NCM ) high performance Driving schools to learn how to drive the cars they have designed.
Have they discoverd things that need to addressed? YES. what are they? well I may be their teacher, but they dont share that info with me. I do know that many items will show up in the C7 as a direct result of the design engineers going to High Performacne Drivers Events.
I think we dont want to confuse the average C5 /C6 owner. Using the brake peddle pump, two person, bleeding method works great.
Old Mar 11, 2007 | 02:10 PM
DZeckhausen
I see where you're coming from now. Your interpretation of James' term "manual bleeding" includes pressure bleeding. However, his definition of "manual bleeding" is the pedal pump method and his definition of "alternative techniques" which "may save some time in the process" includes pressure bleeding. If you continue reading his book, beyond the piece I quoted, he goes on to describe the manual bleeding process, step-by-step. Under the "tools and supplies required" section, he lists "4. One willing assistant to stroke the brake pedal. This tool may be the hardest to find on short notice." He's got that part right! My wife hates it when I ask her to help pump the brake pedal.
To get the ABS unit to cycle, you need to drive the car. Just turning the key (or in the case of the C6, pushing the ACC button) won't do it.
Agreed. The important thing is to change your fluid with some regularity and to use a sufficient amount for the job and the technique. If you're doing a track bleed, a single 1/2 liter of fluid is fine. If you're doing a service bleed (after changing a component), then you can easily use up to three times that amount.
To C6 brake fluid capacity
Old Mar 11, 2007 | 02:24 PM
AU N EGL's Avatar
AU N EGL
Old Mar 11, 2007 | 10:26 PM
teamscr's Avatar
teamscr
Hello all - Dave asked me to take a peek at this thread to see if I had anything of value to offer. Seems like most of it got settled out before I was able to read through, but since I'm already here I'll toss in a few one-liners. Take them with a grain of salt.
1. No matter how hard you hit the brakes, or what type of pressurizing device you use, you can't bleed the fluid trapped in the ABS/TCS/AH module without cycling it with special software. That said, there is only about 3cc to 5cc of brake fluid trapped in there, so it's not such a big deal in the grander scheme of things.
2. There are two varieties of pressure bleeders: the ones you can get for $50 and the ones you can get for $500. The difference is that the $50 models pressurize the brake fluid directly, while the more expensive units use a flexible diaphragm to separate the air from the fluid (like this here: http://buy1.snapon.com/catalog/item....e&dir=catalog). There is a reason that vehicle assembly plants actually store their brake fluid under a vacuum - if you pressurize the air above the brake fluid, the air makes its way INTO the fluid. So, while those bargain-priced pressure bleeders may make the job appear easier, you are actually stuffing air into the fluid in the process. Not air bubbles large enough to see, mind you, but smaller quantities entrained in the brake fluid matrix which will require you to bleed again that much sooner. You get what you pay for.
3. AU N EGL - when have we met? Please refresh my memory. David is perhaps overstating my involvement in the C6 program a little bit, but when did I attend a school of yours?
All for now. And, just for the record, I really miss my Z06...
James Walker, Jr.
teamscr@flash.net
Old Mar 12, 2007 | 12:28 AM
NORTY's Avatar
NORTY
I use a syringe to force the fluid through the bleeder screw up to the M/C. (You have to "pre-fill" the bleeder screw first or that little air bubble will enter the system.) Just make sure the M/C is empty! I've used vacuum systems only to have air enter the caliper via the bleeder screw threads...
