Stage 8 Lock Header bolt part # needed
Old Mar 10, 2007 | 10:14 AM
UNKNOWN's Avatar
UNKNOWN
Banned Scam/Spammer
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Default Stage 8 Lock Header bolt part # needed
Need Stage 8 bolts for kooks install on c6 a4. Part #?
also, use existing GM stockgasket, kook gasket or NEW GM gasket to install new Kooks? GM part #?
ty
Old Mar 10, 2007 | 10:31 AM
hayseed51's Avatar
hayseed51
Most folk just reuse the stock bolts - if you do, be sure to use anti-sieze on them. GM uses a very cool treatment of threadlocker/antisieze that you can't buy over the counter. You can, however buy a set of treated bolts from Chev. Since yours is a 05, you might consider it.
It's hard to beat the GM gaskets too. You won't know what shape yours are in until you get it apart, so I think I would have a new set on hand.
Old Mar 10, 2007 | 10:40 AM
UNKNOWN's Avatar
UNKNOWN
Banned Scam/Spammer
thanks, need part numbers.....anyone?
Old Mar 10, 2007 | 10:53 AM
glennhl's Avatar
glennhl
Sorry, I don't have the part number, but you could probably get it from one of the supporting vendors. However, use the stock OEM gasket with your Kooks.
By the way, I used the Stage 8 bolts on my Stainlessworks header install on my 01 Z28 (LS1) and they are nice, but what a pain to install. I've heard a lot of people leave off the locking feature, but I put them all on even though I really doubt if they would work. The bolt can still loosen a little and that is all it takes to get a leak. However, my stage 8's never loosened, so that was fine.
So when I put the LG Pro's on my 06 Vette, I didn't waste the money on the Stage 8's and just reused the stock bolts. Worked great, I wished I'd listened to everyone on LS1Tech.com when I did my Camaro!
Old Mar 10, 2007 | 11:15 AM
hayseed51's Avatar
hayseed51
Exhaust gaskets are # 1260-0530 (each)
I don't have a # for the bolts - your local Chevy dealer should be good for something... If not, Bob at Fichtner can probably help you, but they do close at noon. (1-800-267-5124)
Old Mar 10, 2007 | 11:01 PM
1vetteracer's Avatar
1vetteracer
Hope this helps.
Part# STG8900
Description of Item: STAGE 8 LOCKING HEADER BOLTS
Application- Fits all LS1 LS2 LS6 Chevrolet (Hex Head)
Part# STG8900B
8mm - 1.25 x 30mm (12 POINT Head)
Old Mar 13, 2007 | 05:24 PM
openhelix's Avatar
openhelix
I ordered mine from Thunder Racing. They have them in stock... http://www.thunderracing.com/catalog...id=20&pcid=301
Here they are on my LG Pros
To Stage 8 Lock Header bolt part # needed
