Help Battery.....
Old Mar 17, 2007 | 08:06 AM
Fore58's Avatar
Fore58
Default Help Battery.....
I appproached my car to morning to open up the door and it wouldn't open. Also there is no light flashing. What happened? I have an 05, maybe I didn't place it in reverse like you suppose to do.
Old Mar 17, 2007 | 08:18 AM
pit-pony's Avatar
pit-pony
Get a battery tender and charge the battery.
..jack
Old Mar 17, 2007 | 08:32 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Originally Posted by Fore58
..... I have an 05, maybe I didn't place it in reverse like you suppose to do.
A manual '05 has to be put into reverse at shutdown or you can return to a dead battery.
Old Mar 17, 2007 | 11:25 AM
Hoonose's Avatar
Hoonose
If it WAS in reverse you might have had an episode of 'DBS', dead battery syndrome, which will drain your battery despite a proper shutdown. Have your battery and charging system checked, and have your dealer download you the BCM reflash software to prevent 'DBS'.
Old Mar 17, 2007 | 05:21 PM
Jbal's Avatar
Jbal
I believe the re-flash reprograms one the ECMs'. Anyway, had mine done(05, Mn6) last september & the car has been perfect.
Best of Luck!
Old Mar 17, 2007 | 06:20 PM
DP Dave's Avatar
DP Dave
I read on the forum that GM no longer performs the reflash. I had my done prior to reading that and all is well.
Old Mar 17, 2007 | 07:19 PM
Hoonose's Avatar
Hoonose
I haven't heard or read that.
Is the reflash screwing something else up?
Old Mar 18, 2007 | 12:17 AM
StarJack's Avatar
StarJack
Check with your dealer to see if they'll do the BCM flash. I have an '06 A6 that would fail to start after 3 days. The BCM was replaced due to other electrical gremlins and now the car will start after sitting almost a week (that's the longest I can stand to let her sit). But if you left the car out of reverse, then you had a "normal" failure, not DBS.
Old Mar 18, 2007 | 02:59 PM
C5-BRUCE's Avatar
C5-BRUCE
You read correctly, but the "reflash" - software update - had nothing to do with the update related to DBS (PIC4166A/B). It was for another reason and only suspended for a couple of days. GM had to reissue the instructions to dealers - nothing to do with the software.
To Help Battery.....
