Re; Ported Intake Manifold
Old Mar 18, 2007 | 11:50 AM
haljensen's Avatar
haljensen
The problem with the FAST HP/$$ isn't the $705 cost of the manifold, add in the fuel rails/injectors, the cowl/firewall modification, the sensor relocation and the parts and labor for all the above. Even if you could do it yourself the parts add quite a bit to the cost.
The ported stock has no additional parts costs. Pay for the porting and shipping (or do it yourself) and you are done.
Guessing at $350 for a known porting job on a stock manifold (exchange) for 10 HP and $1200 ??for the FAST, fuel rails,injectors,cowl mod parts for 20HP.
Yes, I'd like the 20HP but $1200+ for the FAST installed compared to 10 HP @ $350 for the ported stock installed I'll vote with my wallet and go with the ported stock manifold. Retirement doesn't leave a lot of $$ on the table.
Old Mar 18, 2007 | 12:08 PM
glennhl's Avatar
glennhl
Originally Posted by saplumr
I don't think it's ugly.
That is one AWESOME supercharged engine! However, I was worried about covering parts, that it would make them run hotter. I thought about the Alternator cover, but didn't want it to overheat. That carbon graphite cover looks great, but don't you think it would really hold in the heat? I went so far to remove my FRC's.
Old Mar 18, 2007 | 12:28 PM
saplumr's Avatar
saplumr
My engine temps went up only marginally with my setup as you see it. Went through some pretty hot summer weather last year and wasn't really that bad.
Bruce
Old Mar 18, 2007 | 12:55 PM
haljensen's Avatar
haljensen
Default Photos of stock vs stock ported manifolds.
Should be obvious which is ported.
Old Mar 18, 2007 | 01:07 PM
tjwong's Avatar
tjwong
Originally Posted by SpinMonster
In both cases, its not that it isnt worth it but the math is:
Cost of a FAST (- minus) Cost of ported intake = the cost of the gains seen in LG's comparrison.
example: FAST ($705-texas speed) - (250? 350? ported manifold) = $350-$450 for 20 rwhp and 20 rwtq in the midband (not talking peak numbers)......Is that worth it, is the value question. I know someone will say that the FAST port will cost money but the sale of the LS2 will help which obviously you cant sell if you are porting and keeping it.
The two of you do realize that the graph I posted was a comparrison of ported LS2 to a ported FAST? It wasn't stock vs. FAST.
You must be getting one heck of a deal at TSP for the FAST 90 their website it at $875:
http://texas-speed.com/shop/item.asp...d=240&catid=73
Old Mar 18, 2007 | 01:26 PM
STPH8N's Avatar
STPH8N
I've been saving up money to get the intake manifold and throttle body
Ported by Jeremy formato. I have a couple of buddies who told me to do it with him. He just takes your intake manifold and replaces it with one that he already has thats ported my friend told me its like a 20 min install. He also told me everything comes down to about 450 bucks and he drops the price on the tune.
Old Mar 18, 2007 | 02:50 PM
glennhl's Avatar
glennhl
Bruce
That's good to hear, glad you watched the temps. Man, that is one great looking engine compartment and that's a beast of an engine! Great job.
Old Mar 18, 2007 | 05:06 PM
JLinCA's Avatar
JLinCA
no application is better with a 78mm. Your car comes with a 90 so why switch it.
Obviously I didn't know there was a 90 on it already.
Old Mar 18, 2007 | 05:46 PM
saplumr's Avatar
saplumr
Thanks for the props!
Old Mar 18, 2007 | 08:07 PM
haljensen's Avatar
haljensen
Nobody can R & R an Intake manifold on a C6 in 20 minutes!
Old Mar 18, 2007 | 08:10 PM
TRJ's Avatar
TRJ
Thought I would throw this out for whatever it's worth. My car is at Lingenfelters now for the 427 package, which normally includes the FAST intake manifold. They told me that they have now had (4) cars with the FAST manifolds layered construction, start separating and causing them enormous problems. They say that they have re-designed the manifold for the FAST company, and they are working on that re-design now. I took their advice and had them port and de-burr my LS2 manifold for the package, and will return for the re-designed FAST manifold when it is tested, and ready for use. Just for your information...
Old Mar 18, 2007 | 08:28 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
LPE Told me the same
also thay are getting verry close to the same gains as the origonal fast intake . By porting the ls2 one
Old Mar 18, 2007 | 08:50 PM
  #33
Jim_H's Avatar
Jim_H
I hope they redesign it so that the firewall doesn't need to be modified.
Old Mar 18, 2007 | 09:21 PM
  #34
Ferguson's Avatar
Ferguson
nevermind
Old Mar 18, 2007 | 11:55 PM
  #35
SpinMonster's Avatar
SpinMonster
Originally Posted by bunk22
My post had nothing to do with your post. I was simply stating what my results were regardless of what your dyno graph said. But yes, I've seen that graph and know what the comparison was between.
OK, point taken but no one ever said porting the stocker wasnt worth it. What was said in prior threads was that the LS2 ported negates the value of a ported FAST which is 100% false. There are gains over a LS2 by far. Even your gains are probably quoting peak numbers which doesnt mean jack. The ported FAST in the LG graph only had 9rwhp peak and by that number one would say it isnt worht more money for it but looking at the midband makes the whole thing a very different animal. The midband gains are staggering.
It would be just as idiotic to compare cams only on the performance gains at 3000rpm.....the stocker would be the better value then compared to changing to a 232 LG cam then. So why would you compare intake manifolds based on peak numbers at only one rpm where peak occurs?
Funny thing: The FAST falls on it face over 6400 so lets compare bone stock to a ported FAST at 6500. No one would buy one....they're dead even.
Old Mar 19, 2007 | 12:06 AM
  #36
SpinMonster
Once again its 20rwhp and 20rwtq over the ported LS2 in the midband for 1200 and you get to save the 350 for the porting job for the LS2 and sell your stocker for 150 so the total is 700 for 20more HP and 20 MORE tq in the midband.
The graph shows 20 and 20 over the LS2 not 10 over the LS2. Stop reducing it to peak numbers to make the LS2 purchase swallow easier.
For the record, 20rwhp and 20 rwtq is worth 1000 over the LS2 since headers hardly do better for 50% more.
If you investigate further the ported FAST in maxed out applications does 30rwhp and 30 rwtq over stock in the midband. It is one of the best bangs for the buck.
Old Mar 19, 2007 | 12:17 AM
  #37
SpinMonster
I'll beleive that when I see it tested. They are protecting the reputation of a fine shop by not using what is definitely a variable in a product. I have owned 2 FASTS since they came out and have had zero issues.
Someone with this package in NY meet with me over at Lizzard racing wherre I can rent dyno time. We will dyno, remove the LS2 ported and put on my FAST and re-dyno. That will settle the non-sense. Same day, same dyno, same mecanic (ME), no tuner egos, and no variables in weather. I wont even touch the tune which is optimized to the LS2.
Overlay the curves and look at the midband AND peak numbers. LG is a respected tuner with no axe to grind in their 2 services in porting the LS2 or selling a FAST. They themselves did the work and shared the results. They are wrong? BY THAT MUCH???!!! Lingenfelter is right and the graph showing the differences in the 2 optioons is ficticious?
