Free cold air
Old Mar 20, 2007 | 02:02 PM
Whiterock1's Avatar
Whiterock1
Default Free cold air
Someone posted this a while back, but I just got around to doing it. Pull out the two push pins that hold the radiator shroud to the back edge of the front clip. Push the shroud back towards the engine a few inches, and voila! Cold, dense air from under the car now routes to the air cleaner, in my case a K&N Aircharger. No worry about water ingestion, still max flow to the condensor/radiator, but now outside air forced to the aircleaner--not exactly ram air, but a big improvement over keeping the shroud closed. SOTP is there, and it has to be worth several hp at least if the Vararam is supposed to get 30. And the price: 0. I have a funnel of all things holding the shroud open now, but will replace with a turned down dowel to hold both sides equally open. Takes all of 2 minutes and no chance of cutting something you don't want--even the shroud. Back to normal in 30 seconds. Great advice!
Old Mar 20, 2007 | 02:15 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Great post. I love FREE mods. I will look into this for my buddy, and if I can, get some HP Tuners logs on IAT with this mod. Wish I'd seen this before!
I did some IAT logging recently at the drag strip. Cool air to the engine is very important, particularly with a stock tune.
My buddy's C6 Z06 (with its factory cold air induction) had IAT at 150 in the staging lanes, and got down to 104 at about 80 mph and stayed there. So the Z06 nose vent does work. Ambient was about 84 at that time.
I have a Vararam on my C6. My scan showed IAT 93 in the lanes and got down to 84 (ambient) by 100 mph. I don't think this mod will do as good as the Vararam from that perspective - the Vararam sucks from in front of the car away from the radiator. See the 53 degree hotter temp the Z06 had which draws from in front of radiator shroud like this mod.
Here's a table of the timing being pulled at very low IAT's. This is a Z06 table but C6 is very similar. Note that my buddy had 10 degrees being pulled at the start of his run, and still 6 degrees when his IAT got down to 104. That's why these C6's love cool weather and the Vararam so much. Of course a tune takes care of that problem too. This free mod is likely a step in the right direction!
Old Mar 20, 2007 | 04:13 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I've seen these tables before. What is cylinder airmass? How is it measured?
Old Mar 20, 2007 | 05:22 PM
Whiterock1's Avatar
Whiterock1
Wow, I've not seen the tables before. With much colder air and the somewhat venturi effect from the lip of the shroud being out in an active airstream, I would guess more like 10-12 hp available with this mod--especially with the much larger and completely open swept area of the K&N filter. At the 7000 foot altitude here in COS, colder, denser air makes real horsepower--and the price is certainly right!
Old Mar 20, 2007 | 06:41 PM
Silver05GTO's Avatar
Silver05GTO
I'll be doing this in the coming weeks, just got my K&N aircharger in today
Old Mar 20, 2007 | 06:59 PM
cbrf4i1's Avatar
cbrf4i1
don't forget you could also cut the area on each side of the front grill for more additional cold air.
Old Mar 20, 2007 | 08:18 PM
ROD BROWN's Avatar
ROD BROWN
Default I'm stupid!
Can you show a diagram or picture on how to do this mod.Thanks Rod
Old Mar 20, 2007 | 08:34 PM
cbrf4i1's Avatar
cbrf4i1
http://forums.corvetteforum.com/show...d+halltech+cai
see if this helps.
Old Mar 20, 2007 | 09:35 PM
Evilways's Avatar
Evilways
I've cut a hole to mimic the area of the K&N on the radiator shroud. I plan on sticking weather striping to seal it up a bit better . This shouldn't cause any reduction in the air to radiator and increase the air to the intake. Real easy, removed the K&N, used a box cutter to remove a rectangle area, replace K&N. There was no obstructions in the way, yet I've heard of people slicing their a/c lines here. Where are they cutting?
Old Mar 20, 2007 | 09:46 PM
LS1LT1's Avatar
LS1LT1
I love my free semi cold air mod, I haven't track tested it yet (not sure if I even will) but it really seems to make sense that it will give at least some gains.
I also took off the rain guard/cover, cut the tops off of the air filter housings and put in some Fram Air Hog high flow filters (I normally prefer K&N products but these had a rebate for $20.00 off on each one, I paid under $24.00 shipped for each one before the rebate. )
Old Mar 20, 2007 | 10:10 PM
FRC Tom's Avatar
FRC Tom
The LS2 does not pull any timing at wot at 86 degrees IAT.
Old Mar 20, 2007 | 10:43 PM
CDN Vette's Avatar
CDN Vette
Great idea...thank you...will have to check out!
Old Mar 21, 2007 | 08:23 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
No but my buddy's Z06 with factory CAI was 150 in the staging lanes. 11 degrees of advance is about 1/2 of what the car calls for absent timing being pulled by IAT tables.
This is, in my opinion, why we have such a variety of bone stock drag strip results at the stick at the top of the page. One common theme for the low 12 bone stock cars... they did the runs in cold weather. If you go to the track on a 50 degree day and start with a cold engine, you will get the full timing and performance your car will have. On the other hand, if you go on a 90 degree day like me and wait in the staging lanes for 20 minutes, your IAT will be 150 and you will have 11 degrees of timing. That cuts performance dramatically, as you know.
It's also my theory that this is why the Vararam is so effective on stock cars. On an 84 degree day my Vararam car in the same staging lane had 93 degree IAT vs 150 on the stock intake of my buddys. A C6 would be worse than a C6 Z06 btw, the Z06 has a functional vent in the nose. As you can see much less timing is pulled at 93 degrees vs 150.
Old Mar 21, 2007 | 09:08 AM
davekp78's Avatar
davekp78
What is cylinder airmass? Is it measured, or calculated?
Old Mar 21, 2007 | 09:46 AM
BADC64GO's Avatar
BADC64GO
Nice Freebie!
Old Mar 21, 2007 | 10:50 AM
Whiterock1's Avatar
Whiterock1
Originally Posted by cbrf4i1
vredvette came up with the idea. I couldn't find his post, so reposted it after I did it. I just read last night that 1 degree F lower intake air is worth 1 hp. So, even if you just get 15 degrees cooler air, which is a very real prospect, for 0 $ you pick up 15 hp. Not a bad bang for the buck.
Old Mar 21, 2007 | 10:52 AM
Whiterock1's Avatar
Whiterock1
The A/C condensor is right behind the shroud up top. I think that was what a few people cut doing the Vararam.
To Free cold air
Old Mar 21, 2007 | 11:13 AM
maj75's Avatar
maj75
I have been watching the threads on this mod, and I like free stuff too!
One thought that occured to me is that the air that is brought into the nose of the car by this mod would just flow over the radiator support and back over the engine, correct?
If there was a way to create a seal between the hood and the radiator support, would positive pressure be created in this area? The positive pressure should have an additional benefit (ala Vararam) in addition to the lower IAT.
Any ideas on how such a seal could be created? Closed cell foam with the air bridge running through it, glued to the radiator support and trimmed to the contour of the underside of the hood?
Old Mar 21, 2007 | 11:36 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
It's cylinder pressure. I think the MAP sensor measures it, that would make sense to me but I'm not 100% sure. I know this - when the engine is under load it is higher. Full throttle on the drag strip puts you in the lower right columns. I think the only way you go above 1.0 (really .9) is with forced induction.
Old Mar 21, 2007 | 12:28 PM
cbrf4i1's Avatar
cbrf4i1
whiterock, it is my finding if you were to cut 2 holes (roughly 3" x 5'') on each side of the front grill it is much more effective in turns of getting cold air into the engine compartment (verified by the thermometer in my engine compartment) vs the "vredvette" method. of couse do them both if you are looking for the most cool air for a top breather air filter.
http://s155.photobucket.com/albums/s...ent=grill4.jpg
