Just installed headers BIG question
Old Mar 26, 2007 | 09:51 AM
knkali's Avatar
knkali
I wonder if the "noise" is triggering the knock sensors and pulling timing........Hmmmmmmmmm..........someth ing to think about?
Old Mar 26, 2007 | 09:52 AM
valdeztke's Avatar
valdeztke
No, I didn't direct my comment to you. It was more a general comment.
Basically most are "worried" at the new found noise of adding headers because it was something that was always there, yet was conceled nicely with the cast iron manifolds.
With a tune you should have no problems - but I never had my old C6 tuned and I had plenty of valvetrain noise, never any knock
Old Mar 26, 2007 | 09:54 AM
valdeztke's Avatar
valdeztke
You dont get it, do you? Most people worry that the "noise", i.e. the regular sound of a motor running, is bad because now you hear it differently. Nothing has changed - only the amount of back pressure and total exhaust flow.
Someone chime in here please
Old Mar 26, 2007 | 10:00 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
...I hear the sound almost all the time but mostly on the freeway with a slight throttle modulations uphill or downhill
i'd almost be willing to bet the rpms are below 2500 when this occurs.
Old Mar 26, 2007 | 10:05 AM
Zig's Avatar
Zig
it's my understanding that they (gm) moved the knock sensor to the front of the block to help prevent 'other' noises from being interpreted as knock. yes, it's possible but it depends upon how severe the 'noise' is.
Old Mar 26, 2007 | 11:48 AM
knkali's Avatar
knkali
Valdeztke--I understand what you are saying bro. Its ALWAYS been there just hidden. Not sure I like it though.
Zig: I have an auto so I lope along at 60-65 mph at like 1200ish-1500ish rpm that when I hear it the most when gently increasing throttle.
Old Mar 26, 2007 | 12:26 PM
Zig's Avatar
Zig
kinda like the sound you get from low rpms and high gear ?
Old Mar 26, 2007 | 01:11 PM
knkali's Avatar
knkali
Yes Zig
Old Mar 26, 2007 | 03:03 PM
Zig's Avatar
Zig
in that case, i would downshift when you hear it.
oh wait you can't... hhmmm....darn automatic. just ribbing you.
see if you can get your tuner to take out some of the advance for high gear / low rpm use.
i'm assuming you use good (prefer top tier) gas.
Old Mar 26, 2007 | 03:36 PM
knkali's Avatar
knkali
Thanks guys!
Old Mar 26, 2007 | 03:46 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
look at it this way...
Ever heard a top fueler with its Zoomies? That's the sound you can now hear in thinwall stainless headers. It's louder when the engine is under load, and at high rpms & speed there are other noises that drown it out (like your Bullets).
You couldn't hear that sound when you had the cast iron manifolds. Now you're closer to a race car! If you open your headers right after the collectors you can sometimes see fire like dragsters. For sure the popping on overrun shoots fire with the headers open. I have cutouts right by the collectors on my Hurst Olds.
I personally love the sound of headers.
Old Mar 26, 2007 | 04:23 PM
knkali's Avatar
knkali
My tuner, who is a great guy, said bring it by and he will check it out. Sounds to him like I am describing the header "tin can" noise. He has moved my shift points up in D mode so it is not as bad but the stock S mode shift points let the rpms drop lower in 6th before downshifting and it is not very enjoyable. I know leave it in D mode
I might have a set of AR's for sale in a week or two if I cant get my mind around it. Like the growl though.
Old Mar 27, 2007 | 08:16 AM
  #33
6 speed Sid's Avatar
6 speed Sid
Most likely it is the "tin-can" header noise. Personally, I like that sound.
