Emissions inspection in NC
Old Mar 26, 2007 | 01:20 AM
officerp's Avatar
officerp
Default Emissions inspection in NC
It sounds to me adding long tube headers with hiflow cats will not let the car pass NC emmission tests. Experinces with this,fellow tarheals?
Old Mar 26, 2007 | 09:38 AM
ZO6Gal's Avatar
ZO6Gal
I have long tubes with h/f cats and it passed without a problem.
Old Mar 26, 2007 | 10:04 AM
Evilways's Avatar
Evilways
Make sure the computer is not throwing codes,the current program has been in for at least 300 miles and that you have high flow cats. There shouldn't be a problem. If you take it to the actually letter of the law, your cats should never be removed unless faulty and should always remain in stock location. Some areas here in NC do visual inspection only, some do OBD2 and visual and some do the trifecta: visual,OBD2 and the sniffer test. With modern high flow cats, there should still be no issue passing all three unless you have a really **** inspector.
Old Mar 26, 2007 | 11:38 AM
AU N EGL's Avatar
AU N EGL
No problems here. I have TPIS LTs, Random Tech High Flow cats & X pipe plus straight pipes, no mufflers, plus cam
I pass.
To Emissions inspection in NC
