Turbo Or Supercharge
Old Mar 26, 2007 | 05:53 PM
MADMAX1's Avatar
MADMAX1
Default Turbo Or Supercharge
Which is better Turbo Or Supercharge? I don't know which one too pick. I'm looking for reliability/ and longevity. My vette is not a daily driver. Will it hurt resale value Etc.
Old Mar 26, 2007 | 06:20 PM
Smokey1226's Avatar
Smokey1226
how about a 300 shot of N20??? seriously though you need to do a LOT of research before you start to even look at buying. Huge advantages and disadvantages to both setups so start by searching all over the net and then ask questions.
Old Mar 26, 2007 | 08:35 PM
CYA-Vett's Avatar
CYA-Vett
Turbo is better
Yes it will hurt resale, it will also dwindle down the number of potential buyers since some wnat a car closer to stock or stock.
Superchargers use belts (that often break and/or slip) and rob a small amount of HP to make the extra HP, but they build boost slightly quicker.
Turbos work off of the cars exhaust and is considered free HP, turbos will also typically run much more boost, yielding higher HP. Of course these motors were not built for boost so you must keep it at a minimum, like 5-8 pounds. If you build the motor correctly, you can run upwards of 25-30 pounds. Most guys simply slap on superchargers and run low boost and gain about 100HP. But if you rebuild the motor with a lower compression and stronger bottom end, you can easily get 300-400 more HP.
Keep in mind most guys will only post positives of FI. You read very few posts about blown motors, but there are quite a few. For instance, if you foul a plug under boost, that could be the end of you motor.
Neither super or turbocharging are efficient with a mn6, you lose boost when you shift, then have to build it back up. Sure, it happens quickly, but with an auto, the boost never drops.
Most guys will disagree with my synopsis, but, oh well...I have a little V6 turbo with a stock bottom end, I'll take on any supercharged Vette with a stock bottom end
Old Mar 27, 2007 | 09:45 PM
kenw's Avatar
kenw
VIR
Did alot of research and went with the APS-Twin-turbo and 315 gear set on my 06/A6. Install done by Phil at Dynotech with his custom tune. Phil is very serious about turning out reliable as well as powerful cars. Car drives like stock untill you step on it. AMAZING POWER There are alot of ways to go to mod the vette. Good luck with your choice.
Old Mar 28, 2007 | 02:12 AM
LS1LT1's Avatar
LS1LT1
turbo
Old Mar 28, 2007 | 02:46 AM
DSOMC6's Avatar
DSOMC6
Originally Posted by LS1LT1
turbo
Try to ride along in the two different set-ups and judge for yourself.
Old Mar 28, 2007 | 12:54 PM
Wayne O's Avatar
Wayne O
CF Senior Member
For me, I would never use nitrous in a street car. I would also hesitate to use TT or SC applications in a stock, cast-piston engine. Kept at a 'reasonable' power output you'll likely be fine but people often have a tendency to push for a little more....sometimes with disastrous results. You can only exceed the design thresholds of the engine by so much or for so long before a problem will occur.
I'd suggest a 'built' engine. It's certainly more expensive but IMO a strong forged-component, naturally-aspirated engine is unquestionably the best way to go. It also provides better platform for adding a SC or TT in the future (if you can figure out how to hookup with either TT or a SC on top of your built motor).
If you're concerned about warranty repairs or resale value....don't modify your car. If, however, you're more concerned with performance and driving enjoyment....definitely mod you car. Good luck whichever way you decide to go....you'll love the difference.
Old Mar 28, 2007 | 04:14 PM
dashotgun's Avatar
dashotgun
Personally having owned a TTsupra which was modified to around 450 hp out of 3 liters( 180 ci) Turboing was a blast when the boost hits you are gone.
Turboing a torque monster like the the vette should give the best of both worlds the torque then the upper rpm hp. since the engine was not designed for FI there are risks of detonation and destruction and the ultimate longevity of the engine is bound to be shorter.
I personally would not buy a used modified FI car especially one that was not designed to be FI in the first place. I think that if I were to modify my car I would go with the APS turbo system from the looks of it is a high quality piece that yields gobs of Hp and drive ability is like stock until you hit the gas.
A friend had a LPE modified older vette and had the hardest time reselling it as mentioned your market narrows and a most people prefer to have their own modifications done rather then buy someone else's. You never get the cost of the modifications back either so it is not an economic proposition unless you don't car or plan on keeping the car for a long time
Old Mar 28, 2007 | 06:17 PM
MADMAX1's Avatar
MADMAX1
Default Turbo or supercharge I've deceided Anyone used MTI Racing out of Georgia?
Thanks too all for their responses on this subject and I have decided to go aspirated with MTI racing out of Georgia with their stage 2 kit with 410 gears... Hopefully this will cure my need for speed..:rofl
Old Mar 28, 2007 | 06:29 PM
blue racer c6's Avatar
blue racer c6
there is no cure for the need for speed. this is just your first step and good luck
Old Mar 29, 2007 | 09:54 AM
MADMAX1's Avatar
MADMAX1
Default Mti Racing Comments Good Or Bad
I've decided to go with their stage 2 kit with 410 gears. Has anyone had work done by them? Your comments would be greatly appreciated good or bad.. Thanks for all the feedback from the forum people who helped with the decision to S/C or Turbo. But i have decided too just go with the aspirated motor work. Hopefully this will cure the need for speed.
To Turbo Or Supercharge
