I'm looking to build an engine that wil give me the best midrange. Coming out of corners my A4 ends up around 3500 so I need good low end too. So far this is what I have...
Some Intake???
Fast 90mm & Throttle body Do I need the 90 or keep the stock with 75
AFR 205s
LG Long Tubes with Cats
Electric Water pump
Underdrive pulleys
Cam??
Since its and auto
220/224 581.581 115lsa
Take a look at this build, where we started with a new LS2 block, and built the engine up from there. This build was with low end torque as the main consideration. Bob
