Trailer Hitch ?!?!?!?!
Old Mar 31, 2007 | 11:58 PM
  #41
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by haljensen
U-Haul installed a Curtiss hitch on my C6 for around $350 total including hitch, install and wiring.. Rated at 200#'s tongue/2,000#'s tow. Barely noticeable when there's no trailer attached.
Wahooooooooooooo That's the first time I've seen the boat.
Old Apr 1, 2007 | 01:25 AM
  #42
Pontiaker's Avatar
Pontiaker
I have also used most of my performance cars to tow a med size trailer I have, I even raced rice with my 89 Turbo Trans Am that ran 12.20's with my 4x9 foot black flatbed trailer with a Suzuki DR350 dual sport loaded on it. Smoked him pretty easy too. The trailer is custom made with a small drop axle and a GM 5x4/34 inch bolt pattern spindles on it.I normally run an extra pair of wheels on the trailer that match whatever car I have at the time. It looks awesome and pulls like a dream.
Old Apr 1, 2007 | 11:44 AM
  #43
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
Originally Posted by Vet
One issue with towing would be tongue weight. The C6, being a two passenger car with not much trunk space is not designed to hold a lot of weight in the rear (unlike most other vehicles designed to take anywhere from 2 to 6 passengers and a large trunk load of stuff). The rear suspension of the C6 will have less acceptable range / travel than other vehicles. As well, the C6 is already too low to the ground, any extra weight pushing it down would only be a very bad thing. So, I'd think that if someone were to hook up a trailer with decent tongue weight, it would be a problem. However, a small light trailer with very little tongue weight would perhaps not be a problem.
Yes, the C6 has a steel frame... but it is a fairly light steel frame. It is not designed for towing. Remember, Dave Hill and the crew designed this car to be as LIGHT as possible for racing... so that design goal does not go hand in hand with towing. Even at the max tongue weight for a Class I hitch, you'd be ok with just a driver.
If a trailer is absolutely necessary, I like the suggestion to use a motorcycle type trailer... I think that would be ok. After all, the C6 is pretty much a 4-wheeled motorcycle anyway.
The hitches sold for the C6 are Class I, max tongue weight of 200 lbs, max towed weight of 2000 lbs. The cargo capacity of the C6 is around 435 lbs, depending on your options (see door jamb tire sticker), including passengers. For a light weight trailer to tow tires or a bike, a tongue weight of 50-100 lbs would be common, so unless both of the passengers are weighty, there should be plenty of cargo capacity to handle the tongue weight.
Old Apr 1, 2007 | 12:20 PM
  #44
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Even my ex mother-in-law in a stock trailer ........................................ .
Old Apr 2, 2007 | 09:57 PM
  #45
wratran's Avatar
wratran
Originally Posted by Joe_G
Save yourself a few bucks. $202 and $1 shipping.
http://www.etrailer.com/hitch-2005_C...t_Corvette.htm
I've got one, fine product.
And I see NOTHING wrong with towing a trailer with a Vette. How else are you going to get your race tires to the track!
this is exactly what i need to carry DR to the track...plus floor jacks, jackstands, etc...
can you take a picture of the hitch from below and behind the car? I want to check clearance with my exhaust
Old Apr 2, 2007 | 10:04 PM
  #46
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
As a matter of fact when I used my trailer to tote my tires to Sebring, one of my passengers soiled his shorts when he felt how a Corvette can handle.
Don't think anyone sh&t their pants waxing their vette. But what do I know, I don't think I've waxed mine in a year. Just another viewpoint.
Your britches or the car ?
Old Apr 3, 2007 | 08:36 PM
  #47
clubracer6's Avatar
clubracer6
yes I would like to see better pictures from behind. Is it removable?
Old Apr 3, 2007 | 08:44 PM
  #48
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
I always like behind picture's...............
Old Apr 4, 2007 | 07:48 AM
  #49
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I will get some pics and post up. There is a lot of room for exhaust because the factory mufflers are so big. I've got Magnaflow 14336's which are smaller and there is plenty of room.
You could remove it, it's 4 nuts, but you'd want to put the nuts back on the studs or else they will fall back into the frame and get lost. I think they would be hard to fish back out of the frame so putting the nuts back on would be easier.
You really don't notice it unless you are looking for it. The car is so low that you have to really bend over to see it. Since it is black it blends right in.
Old Apr 4, 2007 | 04:53 PM
  #50
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Pervert
Old Apr 4, 2007 | 07:43 PM
  #51
2000droptop's Avatar
2000droptop
St. Jude Donor '07
Default Bborr
Best of luck in the BBORR
Old Apr 5, 2007 | 03:05 PM
  #52
wratran's Avatar
wratran
I have the 14336 also...so it sound like it would work...
Old Apr 5, 2007 | 03:10 PM
  #53
Joe_G's Avatar
Joe_G
St. Jude Donor '08
PLENTY of room. I've been driving my truck so haven't had a chance to take pics. Will try this weekend.
Old Apr 5, 2007 | 09:15 PM
  #54
cmb13's Avatar
cmb13
This thread's still going on?
Old Apr 5, 2007 | 09:32 PM
  #55
LightFighter_GXP's Avatar
LightFighter_GXP
please say no!!!
buy trailer and put on back of pickup!! and put vette on it!!
Old Apr 5, 2007 | 10:11 PM
  #56
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Old Apr 6, 2007 | 08:42 AM
  #57
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Mind your own business. Not everyone is lucky enough to have a wife willing to provide chase vehicle services and cart their tires up to the track for them!
To Trailer Hitch ?!?!?!?!
Old Apr 9, 2007 | 10:14 PM
  #58
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Here's a pic of my behind for you. Note how the FL "save the whales" (are there any whales in FL???) tag matches the C6 emblem so closely!
Old Apr 10, 2007 | 10:08 AM
  #59
haljensen's Avatar
haljensen
With the #14336 Magnaflows.
Old Apr 10, 2007 | 12:00 PM
  #60
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
From a distance you can hardly see it. I think I could make a slide in with a vette emb. and no one would know......
