Long tube headers and check engine light?
Old Mar 28, 2007 | 09:44 PM
fright88's Avatar
fright88
Default Long tube headers and check engine light?
Just wondering how many members are running long tubes without a tune have check engine lights? Thanks for any help.
Old Mar 28, 2007 | 09:46 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
I never got any light or codes
i think the key it to make sure you put the 02 sensord back in there SAME EXACT LOCATION on the new headders
Old Mar 28, 2007 | 09:50 PM
achilds's Avatar
achilds
I didn't have any codes, but I went ahead and had the tune anyway. It well worth it, because you really want the engine optimized to work with the headers. If you don't you will most likely be leaving quite a few ponies in the barn!
Old Mar 28, 2007 | 11:01 PM
cbrf4i1's Avatar
cbrf4i1
there are o2 sims kits that can take care of CEL even with no cats applications. pm me for source if needed.
Old Mar 28, 2007 | 11:05 PM
fright88's Avatar
fright88
I will be getting a tune in a couple months. There arn't many places around here that can dyno tune
Old Mar 28, 2007 | 11:26 PM
CDN Vette's Avatar
CDN Vette
never had engine codes after header and x pipe install without tune.
Old Mar 28, 2007 | 11:37 PM
Oli1313's Avatar
Oli1313
St. Jude Donor '09
Had codes until cbrf4i1 fixed them with his sims.
Old Mar 29, 2007 | 01:01 AM
glennhl's Avatar
glennhl
LG Pro Long Tubes, uncoated, no tune, no codes. Knock on wood!
Old Mar 29, 2007 | 06:11 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
American racing headers, uncoated, w/ cats. P0420 and P0430 every day until tuned. I could turn them off with an Actron scanner but they came back.
Old Mar 29, 2007 | 07:45 AM
Max@Cartek's Avatar
Max@Cartek
With a proper tune you should have no codes being thrown.
Max
Old Mar 29, 2007 | 07:55 AM
fright88's Avatar
fright88
Is this a joke? CBR F4i??
Old Mar 29, 2007 | 09:45 AM
mfoti's Avatar
mfoti
Melrose LTs with high flow cats. Code showed up after about 2 months...I delete and it comes back within a few days. I plan on getting tune before the end of the year so i am holding out until then.
Old Mar 29, 2007 | 10:59 AM
vettl83's Avatar
vettl83
Kooks lts w/high flow cats, codes 420 and 430 set every two to three days after clearing. Tune will take care of it in April, motor runs just fine with em set.
Old Mar 29, 2007 | 11:01 AM
DarthStimpy's Avatar
DarthStimpy
Quick Read on 02 sims.
And the DIY
Though I'd pay the $30 for the pre-made one
Old Mar 29, 2007 | 11:11 AM
cbrf4i1's Avatar
cbrf4i1
no joke sir. $25 solves the issue.
Old Mar 29, 2007 | 12:01 PM
fright88's Avatar
fright88
Ok sorry I had a mis read. I thought the sims were called cbrf4i which I thought was a typo or something because of the bike. Sorry about that.
Old Apr 5, 2007 | 06:18 PM
Ultimate CC's Avatar
Ultimate CC
you could also use spark plug foulers...
To Long tube headers and check engine light?
Old Apr 5, 2007 | 06:40 PM
BaBa Boey's Avatar
BaBa Boey
Melrose headers sells a signal conditioner which supposedly will eliminate the O2 sensor code.
http://www.melroseheaders.com/produc...onditioner.php
Old Apr 5, 2007 | 10:45 PM
DSOMC6's Avatar
DSOMC6
It appears some throw a CEL and others do not?
I had LG long tubes and Halltech and it threw a CEL intermittently. I dyno'd it (baseline for F/I install) and it was running fairly rich which was causing it to lose some HP.
Get a tune with LT headers to adjust the Air/fuel, among other things, and get the full power potential!
Old Apr 6, 2007 | 01:10 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Moi too ;-)
