Rear Ruro Lights For C6
Old Mar 30, 2007 | 09:01 PM
67cam's Avatar
67cam
Cruising
Default Rear Euro Lights For C6
CAN SOMEONE HELP ON INSTALLING REAR EURO LIGHTS FOR C6.
Old Mar 30, 2007 | 11:51 PM
2LT-Z51's Avatar
2LT-Z51
what kind of help do you need??
Old Mar 31, 2007 | 07:54 AM
67cam's Avatar
67cam
Cruising
How to wire it up to the relays and what connector did you used, all 2
wire or 3 wire for the top lights and 2 wire for the bottom lights. Thanks
for the help.
Old Mar 31, 2007 | 10:29 AM
LEAVINU's Avatar
LEAVINU
What do these lights look like- pics please?
Old Mar 31, 2007 | 12:17 PM
vettedream420's Avatar
vettedream420
Post Pics 4 Sure--im just curious
Old Mar 31, 2007 | 12:38 PM
c6speedjon's Avatar
c6speedjon
where did you get these? wanna c pics as well. do they make them for the front too?
Old Mar 31, 2007 | 01:31 PM
2LT-Z51's Avatar
2LT-Z51
10440714 RH euro lens
10440713 LH euro lens
88988117 3 wire plug
88988109 2 wire plug
relays and diodes misc plugs and wire.....
you can also get the euro lens and trim the stock harness to plug into the red part of the euro lens (amber part is not connected)
i had to do that while i was trying to figure out how to make it work...
i have to re-draw what i did with the relays (cant find that paper work... )
basically using the center brake signal to run the red and the regular signal to run the ambers
here are some pictures....
Old Mar 31, 2007 | 08:57 PM
67cam's Avatar
67cam
Cruising
What kind of relays and diodes are you using and where do you get them. If you can re-draw what you did with the relays and diodes, that would be a big help. Thanks.
Old Mar 31, 2007 | 11:41 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
I think what y'all ought to do is fly Stan stateside for beer and pizza.
Old Apr 1, 2007 | 03:15 AM
2LT-Z51's Avatar
2LT-Z51
i'm game....
working on the drawing.... i'll post it here when i'm done....
Old Apr 1, 2007 | 12:33 PM
67cam's Avatar
67cam
Cruising
Thank you for working on the drawing.
Old Apr 14, 2007 | 01:26 PM
siggi-annette's Avatar
siggi-annette
Jes
Siggi
Old Apr 14, 2007 | 01:38 PM
2LT-Z51's Avatar
2LT-Z51
this is what i had to do.....
relays are "bosch" type with no/nc contacts (spdt)
diodes are 6a rated
rectangles are the relay coils (i used 5 relays)
sorry it took so long... had to redraw it... and i just fixed a mistake...
Old Jan 3, 2009 | 07:05 PM
Swingwing's Avatar
Swingwing
I'm working on a diagram to show how 2LT hooked up his relays.
Old Jan 3, 2009 | 07:58 PM
danl72's Avatar
danl72
Looks good.
Old Jan 4, 2009 | 03:14 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Looks nice.
Old Jan 4, 2009 | 08:50 AM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Were you able to purchase these pieces seperately, and if so, what are they called and where did you get them? :-)
Thanks so much, Steve
To Rear Ruro Lights For C6
Old Jan 4, 2009 | 01:28 PM
tjwong's Avatar
tjwong
I used the Euro tail lamp harness, modified it for the second amber lamp instead of the rear fogs, and reprogrammed the BCM with a different program to run the lamps. The only issue is that you loose your tire monitor system, or if you don't have XM then you can keep everything working. Also with the non US Spec program you don't have daytime running lamps either which for me is A OK.
Old Jan 4, 2009 | 07:25 PM
rwarhol's Avatar
rwarhol
Be careful those relays get very hot, tried them on my dodge pickup,took them off
Old Jan 5, 2009 | 12:51 AM
Swingwing's Avatar
Swingwing
Steve,
Evidently 2LT made those pieces by removing the glass bulb from the plastic bulb socket and adding his own wires/connectors. The other brown and gray connectors are pricey...$44 and $36 each from GMPD!
