LS2 cam sensor: location?
Old Apr 1, 2007 | 10:43 AM
Red Gump's Avatar
Red Gump
Default LS2 cam sensor: location?
I need to clarify its location. also, is it possible to change without pulling the engine? anyone got pics or a step-by-step?
Old Apr 1, 2007 | 11:02 AM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
I had one replaced and it is accessible from under the car. Somewhere near the starter I believe?
No engine pull.
Old Apr 1, 2007 | 11:07 AM
Red Gump's Avatar
Red Gump
No engine pull.
so it's not part of the timing set? I thought I heard/read that it was part of the timing sprocket.
Old Apr 1, 2007 | 12:12 PM
KarlK's Avatar
KarlK
Just checked service manual....CMP sensor is 3 pin Metri-Pack located drivers side, an inch or twp above the front lip of oil pan.
Old Apr 1, 2007 | 05:59 PM
Red Gump's Avatar
Red Gump
thanks guys. I'll have to run my codes again to see what's popping up. do you guys have the same codes as us c5's?
Old Apr 1, 2007 | 08:19 PM
CYA-Vett's Avatar
CYA-Vett
The cam sensor is on the front of the engine, on the left side of the harmonic balancer. If you must change it, you are in for a pretty large job. One of its bolts is under the balancer so you must remove the balancer, but to remove the balancer you must remove the steering rack. Good luck, it's not hard, just a bit of work...
Old Apr 1, 2007 | 08:27 PM
see5's Avatar
see5
Sensor is on the front cover upper right as shown but If you do not have a LS2 cam sprocket it cannot be read by the sensor.
Old Apr 1, 2007 | 09:26 PM
CYA-Vett's Avatar
CYA-Vett
Do you have an LS1 or LS2?
The LS1 sensor is in the back of the motor...
Old Apr 2, 2007 | 10:36 AM
Red Gump's Avatar
Red Gump
it's a '97 c5 pcm with an ls2 engine.
Old Apr 4, 2007 | 04:44 PM
Red Gump's Avatar
Red Gump
you don't happen to have a diagram you could post/email, do you?
Old Apr 4, 2007 | 04:49 PM
see5's Avatar
see5
That is a picture of one l^l.
Do you want the electrical diagram?
Old Apr 4, 2007 | 05:41 PM
Red Gump's Avatar
Red Gump
ah, gotchya--was hoping for something illustrating where it's located on an assembled engine. I'm trying to learn this stuff but man, I'm dense with mechanical.
Old Apr 4, 2007 | 05:48 PM
see5's Avatar
see5
Send me your email address and I will send you the full course.
Old Apr 4, 2007 | 06:47 PM
Red Gump's Avatar
Red Gump
pm's are acting up for some reason--eric . keiber @ gmail . com.
thanks!!!
To LS2 cam sensor: location?
