fix for creaking roofs
Old Apr 3, 2007 | 03:42 PM
gatorp's Avatar
gatorp
Default fix for creaking roofs
Thought I`d share a fix that worked!!! After reading many posts about "creaking' tops...the one that said "the only contact of the roof to the car is the weatherstiping' made sense to me. I used a thin film of SUPERLUBE....rubbed on with my fingers...voila...the creaks stopped!!! (be sure to rub on the rear wetherstrip too...when I only put it on the front first,the front creaks stopped,but I had a "pop" from the rear when backing out of my driveway...put it on the rear also and all QUIET~) SUPERLUBE ia a teflon based gel like lubricant which doesn`t attract dust,dirt,etc.I also had the "chattering" gear shift **** so while I was at it...I loaded the gear shift **** with the same lube...wiping away the excess as I pushed the **** on...to my surprise...NO MORE Chatter!!!
Old Apr 3, 2007 | 11:32 PM
Lipps C5's Avatar
Lipps C5
If your car is under warranty go to the dealer and have them replace the plastic guides in striker left/right sides.
Old Apr 4, 2007 | 02:33 AM
LS1LT1's Avatar
LS1LT1
Thanks for the tips.
Old Apr 4, 2007 | 08:54 AM
AFVETTE's Avatar
AFVETTE
Is this the product - http://www.plumbingsupply.com/lube.html and where did you buy this??? My solid panel is tight and squeek/rattle free, but my Lexan top I bought after the fact makes an annoying "squeek" or "rubbing" sound right by my right ear where the window seats into the weather stripping. It drives me crazy when I have the windows up. I can make it stop by pressing on/around the weather stripping.
I removed the glass top and went back to the solid panel because of this.
Tom
Old Apr 4, 2007 | 07:02 PM
gatorp's Avatar
gatorp
HI tom,thats the stuff....worked for me!! I own a hardware store and have carried this product and used it for many things...has the consistantsy of toothpaste/gel. i only rubbed a dab for the whole front and a dab for the whole rear...totally stopped the annoying creaks which always happened whenever I would drive over bumps.gator
Old Apr 6, 2007 | 08:14 AM
AFVETTE's Avatar
AFVETTE
Cool, aside from buying on-line, do auto parts stores like Advanced Auto etc or Home Depot etc sell this stuff??
Thanks again
Tom
Old Apr 6, 2007 | 11:16 AM
05_C6Z51's Avatar
05_C6Z51
Yep, he's right. Teh dealer replaced bu plastic guides as there is a TSB for them. When he did so, he told me I will eventually hear creaking and to greases the rollers and metal plate on the latch. Sure enough, I did and its been very quiet.
Old Apr 6, 2007 | 02:16 PM
DrivnXcitment's Avatar
DrivnXcitment
Thanks again
Tom
Yes, do tell, where else can you get this stuff other than online?
Old Apr 6, 2007 | 07:36 PM
gatorp's Avatar
gatorp
try a hardware store,i sell it so i would think there are others...instead i`m sure any gel type lube would work too...like di-electric grease for instance...you only need to rub a small ammount well into the rubber...not enough that you can it except that there is a very thin coating...
Old Apr 7, 2007 | 07:54 AM
AFVETTE's Avatar
AFVETTE
Geez, I have a tube of Dielectric Grease made by Permatex in the garage left over from my C4 days. That was the recommended lube to help keep the C4's weatherstriping from premature aging.
Thanks for the memory jogger.
Tom
To fix for creaking roofs
