C2042: Traction COntrol Malfunction
Old Apr 5, 2007 | 01:15 PM
vette-oholic's Avatar
vette-oholic
Default C2042: Traction COntrol Malfunction
Well, it happend again today for the 6th time in 2 years.
Reduced Engine Power and Service Traction Control.
I drove the car to the shop so the code would be active and it was NOT a fun drive. stalled once, but made it.
code C2042 was the cause and now i will await repair.
BTW - the throttle body was already replaced to fix this problem, but it apparently, it didnt work.
Does this qualify for lemon law at all?
not sure what to do.....
Old Apr 5, 2007 | 01:44 PM
Arthur6's Avatar
Arthur6
This could be the "Steering Wheel Wires" comming loose.
Lots of info on here about this.
It's a simple fix (if that is the problem) at any dealer.
http://forums.corvetteforum.com/show....php?t=1661808
Old Apr 5, 2007 | 02:02 PM
vette-oholic
thanks, but i never move my telescopic wheel and i thnk it's always IN all the way.. so not sure about this.
Not sure if i shoukd mention this wire to the dealer.
and is there a TSB for this.
Old Apr 5, 2007 | 05:26 PM
vette-oholic
anyone?
Old Apr 6, 2007 | 10:58 AM
Vetteinplano's Avatar
Vetteinplano
My 05 did this three times and reset. (normal driving, no WOT). Two weeks ago, service stab sys light stayed on.
Took it in to the dealership, found the left wheel sensor wiring clip broken (tech said it looked like it was broken from orig installation)
He cut off the old narness end, grafted in a new one.
Car has been fine for 1,200 miles.
Old Apr 6, 2007 | 12:05 PM
vette-oholic
Well.. dealership says that they 'found a loose ground'
not sure where yet - they're calling me back after lunch.
any thoughts?
Old Apr 6, 2007 | 12:24 PM
calemasters's Avatar
calemasters
No, not technically after 18 months. But then again, it's up to the jury.
Old Apr 18, 2007 | 11:08 PM
rico70458's Avatar
rico70458
4th Gear
Default Service Traction System
Hey guys i'm new to the forum and just bought my first Vette recently. I had this very same problem [Service Traction System] and began reading to see if anyone else has had this same problem. The first thing i did was replace the mass air-flow sensor and thought that did the trick but sure enough i got the same thing again. My local Chevy dealer doesn't have a clue and claims they can't diagnose the problem cause i replaced the blose stereo but they won't listen to reason when i explain to them that the car was having the same problem before i touched the damn stereo. I also read here about a harness in the steering column and or a bad wheel sensor causing similar symptoms.
Old Apr 19, 2007 | 09:54 AM
vette-oholic
Are you getting Reduced Engine Power at the same time?
If so, you need to get it into the dealer while you are having this problem.
Old Apr 19, 2007 | 10:34 AM
rico70458's Avatar
rico70458
4th Gear
Yes reduced engine power and no speedometer neither on the HUD nor the dash. And if i let it sit over night the next morning it will be fine for maybe a day or two or as little as a few starts. The dealership i took it to says they can't do anything unless i reinstall the Blose system back and i got the feeling that they really didn't want to work on it. And they're the nearest "Vette speacialist" go figure. I guess i'll have to try this other Chevy dealership in my area.
By the way is yours fixed and where was the loose ground? It really sounds like that could cause this problem cause its got to be something electrical. I read on another post that while replacing the turn signal bulbs it activated the Service traction system and turned out to be he hadn't seated the bulb in properly, go figure.
Old Apr 19, 2007 | 11:16 AM
vette-oholic
My speedo has always worked - so thats a little different.
If I let mine sit for a couple of hours, it has aways started working again. I will have to look at the paperwork at home to give you specific details on the repair, but i believe it was something behinf the tire - maybe an electronic brake module? I will post more details later.
I was getting the problem every 2-3 k miles that i drove.
I have only gone a few hundered miles since repair - so dont know if its fixed yet. I do know that the problem they fixed is the 1st Ive heard, so i doubt yours is the same. did u see the post where it talks about the telescopic steering wheel causing the same problem?
Old Apr 19, 2007 | 11:34 AM
Dgatto's Avatar
Dgatto
You need 3 bring backs for the same problem for the lemon law.
Old Apr 19, 2007 | 11:45 AM
vette-oholic
But...
1. Do they need to try a repair each time, or is just bringning it in good enough?
2. IS there a time limit? some are saying 18 months.
I live in NJ.
Old Apr 19, 2007 | 11:51 AM
vette-oholic
http://www.state.nj.us/lps/ca/ocp/lemguide.htm
this website is good.
it says 3 attempts for repait must be made in 2 years or 18000 miles, whichever is 1st. or the car must be out of service 20 calendar days or more. hopefully my car is fixed now because next month will be 2 years.
Old Apr 19, 2007 | 12:42 PM
rico70458's Avatar
rico70458
4th Gear
Yes i did see the post about the Telescopic steering harness coming loose, thanks and looks like that'll be the next thing i try.
Old Jun 14, 2007 | 12:47 PM
vette-oholic
Well the repair did not work. the other day i received the reduced engine power, traction control again after driving about 1/2 mile from my house. had to turn around and get the other car. was mighty pi$$ed too cause i was on my way to the shore on a BEAUTIFUL day.
This is the 4th time the car has been in for the same exact problem and major repairs have been attempted twice - unsuccessfully.
I think it's time to get this concern elevated.
anyone have any lukc with a simiar situation?
Old Jun 14, 2007 | 01:05 PM
RRVettes's Avatar
RRVettes
I had a "service traction control" warning that popped up frequently, but I did not check the code. There was a definite change in handling when the warning came on. The dealer replaced a sensor in the steering column a month ago and no more STC warnings since.
To C2042: Traction COntrol Malfunction
Old Jun 18, 2007 | 03:06 PM
vette-oholic
ok. they narrowed it down to a faulty potentiometer in the gas pedal and the it was replaced. hopefully this is the last i will see of this problem. will let u now
Old Jun 22, 2007 | 12:05 AM
rico70458's Avatar
rico70458
4th Gear
I'm still getting the STC warnings also and along with the reduced power my speedo gauge and HUD do not register either. Are any of you also experiencing any other wierd symptoms along with the reduced engine power?
Old Jun 4, 2008 | 02:02 PM
mo-shy's Avatar
mo-shy
Default Reduced Engine Power and Service Traction Control!!!
I have the same problem yesterday
any one have idea how i can repair this problem?
