Oil weight Question...
Old Apr 5, 2007 | 08:19 PM
tacobuilder's Avatar
tacobuilder
Default Oil weight Question...
Getting ready for my first oil change. I live in Phoenix and the summer temperatures easily top 110 daily. My question is can you use 10-30 Mobil 1 versus 5-30 Mobil 1. Not being an oil wizard it seems the 10-30 might be better at those daily temperatures, especially stuck in traffic. Any input is appreciated.
Old Apr 5, 2007 | 08:25 PM
johnodrake's Avatar
johnodrake
Moderator
The first number is the cold viscosity the second is the hot viscosity. Use what GM recommends
Old Apr 5, 2007 | 08:28 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Not sure if it's in your owner's manual at the back, but there could be alternative viscosities that you can use, under certain conditions. If not, use what the mfr. says to use, per above post.
Old Apr 5, 2007 | 08:29 PM
Mad*Max's Avatar
Mad*Max
Why do you want to use something different? Just follow the manual's recommendation of 5W30.
Old Apr 5, 2007 | 08:43 PM
JAXKXX's Avatar
JAXKXX
Old Apr 5, 2007 | 11:30 PM
haljensen's Avatar
haljensen
At 110° the 5w-30 and 10w-30 are the same 30 weight oil. Use the 5w-30 just like chevy recommends.
Old Apr 5, 2007 | 11:41 PM
xs650's Avatar
xs650
Bask in the olden daze, 5W-30 broke down faster than 10w-30 so 10w030 was better for high temperatures and hard usage.
Modern synthetics like Mobil 1 no longer have that problem so there is no reason to not use 5W-30 in your climate.
M1 10W-30 would do no harm in your climate, but 10W-30 no longer offers any advantages over 5W-30.
To Oil weight Question...
