Disclaimer: I did a few searches and could not find this info.
I have a set of Z51 rotors and brackets to install on my 2005 F55 vert this weekend. Is the OD of the front rotors larger than the 2005 base/F55 fronts?
Yes, they are larger. You can use them with the Z51 caliper brackets. Be aware those brackets are torqued to 125 ft.lbs. so they are tough to get off and must be re-torqued to 125 when installing them.
FYI, the caliper guide pin bolts should be torqued to 23 ft. lbs.
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Thanks in advance.
Yes the OD of the Z51 rotors is larger than the base or F55 on 2005-06 models.
