rear end question
Old Apr 9, 2007 | 05:28 PM
purple727's Avatar
purple727
Default rear end question
i have an 05 C6 A4. non Z-51. would like to have the 3.42 put in it. is this basically a ring gear and pinion swap out?....thx
Old Apr 9, 2007 | 05:58 PM
Radical05's Avatar
Radical05
Can be but if I were you I would just get a DTE rear end for swap out and be done with it.
Old Apr 9, 2007 | 09:54 PM
gizsmo0's Avatar
gizsmo0
Old Apr 10, 2007 | 01:17 AM
Cookee's Avatar
Cookee
It will also involve some adjustment to engine/trans control module. Like setting the new ratio and adjusting the shift points.
Old Apr 10, 2007 | 08:44 PM
purple727's Avatar
purple727
thanks for the info...just doing a little home work on it. was going to ask about the speedo adjustments etc. got that answer as well.
Old Apr 11, 2007 | 11:13 AM
haljensen's Avatar
haljensen
I seem to remember posts that said the 2.73 housing was only for 2.73 gears. If you wanted other gears you had to upgrade to the 3.15-3.42 housing.
Old Apr 11, 2007 | 11:30 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Default Save a thousand dollars!
Drive up to see forum sponsor Cartek in NJ and save $1K over anyone else and they will do it for you while you wait.
Old Apr 11, 2007 | 11:24 PM
Max@Cartek's Avatar
Max@Cartek
We're running a special right now. $1195 installed with your choice of gear. Give us a call or shoot me a PM if you are interested.
Max
Old Apr 12, 2007 | 07:23 PM
purple727's Avatar
purple727
a bunch of great info....thank you
To rear end question
