Fast intake
The 411 sir is that the 3 pieces are sealed with orange high temp, off the shelf, RTV silicone. I personally found it to be lacking in some areas when I opened all of the eleven of them that I have installed personally for others without a single issue.
A check on LPE's website shows the FAST as a part of every single NA engine package they offer, so they haven't pulled anything. They use LS6 manifolds for their FI stuff. This is logical. If this thread is still active Monday, I'm calling LPE for clarification, because if there is a problem I want to know.
I just did the lpe 403 package and they did not use the fast because of the issue with them comming apart
Call LPE and ask for Kevin
He will tell you the scoop
BTW
LPE stopped using them months aho like oct of 06
but it has not been updated on there site
I know LPE makes the adapter kit and I know FAST refuses to make a new manifold for the C6. I also know FAST gets backordered on the manifolds from time to time, which would screw up LPE. So if I'm LPE, I'm developing my own manifold about now. I'll all monday and report back.
