Fast intake
Old Apr 12, 2007 | 02:12 PM
sux2bme's Avatar
sux2bme
Default Fast intake
Here is the question of the day.
I have ported and polished my heads and upgraded the springs and my cam to 222/224 581 112lsa,
I alreadey have headers and exhaust and a cold air, I'm putting everything back together on saturday. The shop that I deal with has a FAST intake on there shelf.
Do I spend the 1K and buy it?
Are the gains with the money?
Old Apr 12, 2007 | 02:25 PM
AintQik's Avatar
AintQik
They are like 15 to 20 rwhp depending on mods. $1k canadian? Hope the heck so. Worth it? I dunno I like mine and all I just wish it pulled higher than 6500. I've got a stroker so it makes a difference to me, stock bottom ends its not so bad.
rj
Old Apr 12, 2007 | 02:41 PM
sux2bme's Avatar
sux2bme
He wants $1200 Canadian
Old Apr 12, 2007 | 02:42 PM
vr6aaron's Avatar
vr6aaron
Get it ported first, its worth it.
Old Apr 12, 2007 | 02:45 PM
sux2bme's Avatar
sux2bme
No one in my area knows how to port the plastic?
Is this something I can do?
Old Apr 12, 2007 | 03:00 PM
TRJ's Avatar
TRJ
sux2bme,
I just finished having the 427 CID 550/560 Lingenfelter package installed on my 2007 C6. Included in that package is supposed to be the FAST Intake Manifold. I was not given the FAST Intake Manifold, but instead, the LS6 Intake Manifold modified by a company for Lingenfelter. The reason, I was told that Lingenfelter had too many FAST Intake Manifolds start seperating, and leaking. (3 layer composite material) They have submitted a design change to FAST Inc. which they supposedly are considering now.
Just thought I would pass on this information to you. Good luck with whatever decision you make...
Old Apr 12, 2007 | 03:07 PM
TTRotary's Avatar
TTRotary
No one in my area knows how to port the plastic? Is this something I can do?
Yes, with a dremel+ sanding drum attachment. You will see a lot of cleanup work in the area where the three pieces mate, and where the runners meet the plenum. I spent 5 hours on mine. This is worth another 10hp over the 15 mentioned.
Regarding the post above - I fail to see how the manifold can separate on a NA application, since the pieces are bolted together. Maybe at 12 psi it's another story... You do have to be very careful bolting the top piece back on, so you tighten evenly around the perimeter of the gasket, letting the top piece gradually sink into the gasket. I used Loctite to be sure it doesn't move.
Old Apr 12, 2007 | 03:45 PM
TRJ's Avatar
TRJ
Again, I am relaying information given to me by Lingenfelter people. The use of the FAST Intake Manifold was stopped on all packages, due to separation, and leaking. If further information is needed, a call to Lingenfelters would probably be in order.
Old Apr 12, 2007 | 08:12 PM
SpinMonster's Avatar
SpinMonster
A reseal prior to install will prevent that issue and it costs 5 bucks. I surprised they would bash a product that is installed by most other tuners without issue.
Old Apr 12, 2007 | 08:26 PM
saplumr's Avatar
saplumr
For some strange reason Lingenfelter is the only one reporting such an issue.
Old Apr 12, 2007 | 08:30 PM
Kappa's Avatar
Kappa
I'd probably get it ported too. I know a few people who had FAST intakes installed and then later went back in to get them ported.
Old Apr 12, 2007 | 08:37 PM
TRJ's Avatar
TRJ
In my conversation with them about this issue, they indicated that some serious problems had been caused by this separation on four cars, and they had to make good for all the repairs. I had actually been looking forward to getting the FAST Intake as part of the package, but in the face of their explaination, accepted the modified LS6 Intake instead...
Old Apr 12, 2007 | 10:14 PM
vr6aaron's Avatar
vr6aaron
Cory Harris can ported, or you can buy one from Vengence Racing
Old Apr 13, 2007 | 12:15 AM
Max@Cartek's Avatar
Max@Cartek
+1
Shoot me a PM if you are interested in port work for the FAST.
Max
Old Apr 13, 2007 | 02:46 PM
SpinMonster
4 cars
reseal it when you buy it
Old Apr 13, 2007 | 04:40 PM
TRJ's Avatar
TRJ
Originally Posted by SpinMonster
4 cars
A few staples, a little super glue here and there, should work....
Old Apr 13, 2007 | 04:45 PM
hpjunkie's Avatar
hpjunkie
What do you use when you reseal the intake and do you use it every where the seal is.
To Fast intake
Old Apr 13, 2007 | 04:52 PM
SpinMonster
I guess that shows your knowledge level.
The 411 sir is that the 3 pieces are sealed with orange high temp, off the shelf, RTV silicone. I personally found it to be lacking in some areas when I opened all of the eleven of them that I have installed personally for others without a single issue.
Old Apr 13, 2007 | 05:24 PM
Max@Cartek's Avatar
Max@Cartek
We've done lots of installs with the FAST intakes and have never had an issue.
Max
Old Apr 13, 2007 | 07:06 PM
TTRotary's Avatar
TTRotary
Is this still going?
With something like 12-16 bolts around the perimeter which screw into nuts, not plastic, it is damn hard to imagine how the three intake pieces (which are REALLY strong, thick Nylon castings), could come apart. This thing is so solid that I could probably stand on it without any problem, and I weigh 235.
The manifold is delivered with the bolts hand-tight. So of course, if the installer grabs the FAST out of the box, doesn't tighten anything, and slaps it on a TT engine that will run 12 psi boost, you may well have some leakage (Duh). That said, a one-piece manifold like the stocker LS6 is probably preferable for FI because it is permanently welded with no gasket. But I am sure that if you put enough boost through one of those, you can crack them too.
A check on LPE's website shows the FAST as a part of every single NA engine package they offer, so they haven't pulled anything. They use LS6 manifolds for their FI stuff. This is logical. If this thread is still active Monday, I'm calling LPE for clarification, because if there is a problem I want to know.
