runflat repair help
Old Apr 12, 2007 | 09:41 PM
speedneed's Avatar
speedneed
Default runflat repair help
Anyone know the proper way to repair/patch a runflat tire? I want to make sure mine is done right. Picked up a nail. Left a hole you can slide a 6 penny nail in and out of.
Old Apr 12, 2007 | 10:01 PM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
Nothing different than any other tire. The runflats have a stiff side wall to support your car when you have a flat. Very hard to mount new tires with the stiff side walls. I did my new ones this week and it took forever to get them to seal.
Old Apr 13, 2007 | 12:52 AM
C5pilot's Avatar
C5pilot
Incorrect. It's a plug/patch combo. The hole can only be so big, and so close to the sidewall. Leave it up to the pros. GY says a runflat can be repaired once without losing it's speed rating if done properly. If they're under 12 months and 12K miles they're under warranty.
Old Apr 13, 2007 | 07:55 AM
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
Pretty sure that the same as any other tire...
Old Apr 13, 2007 | 11:52 AM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
Correct, it is the same as any other tire and can be repaired with a "mushroom" patch/plug combo so long as its in the tread and not too close to the sidewall.
Old Apr 13, 2007 | 05:14 PM
SpinMonster's Avatar
SpinMonster
There is a specific repair kit from goodyear for the repair of runflats and as stated above they maintain the speed rating. The 6 penny hole is fine. If it was smaller it gets reamed out anyway to accept the plug or repair kit. I personally repair all my flats myself with a plug kit as a regular tire store would use on any tire and I have gone 180mph on a simple plug repair.
Get whatever makes you feel safer but if you dont go over 100mph I would do a simple plug. Mine lasted from the week I bought the car untill I got new tires on my 2005 z51.
Old Apr 26, 2007 | 11:47 PM
C6_NITPICKER's Avatar
C6_NITPICKER
I just took a nail in the rear tire. Did I understand correctly that this is under warranty? My car has 1200miles 1 month old. Who do I contact if it is under warranty? Does it have to be a GY repair or can someone like Americas Tire Company do it?
Old Apr 27, 2007 | 01:35 AM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
There should be a goodyear warranty card in with your owners manual packet. There is an 800 number to call for authorized repair facilities in your area.
Old Apr 27, 2007 | 10:12 AM
BC Bob's Avatar
BC Bob
I picked up a cement nail that went in at an angle, but dead center in the tread. Used a plug kit I bought from Walmart. It's held up for the last three months with no leaks and several dyno runs.
To runflat repair help
