Wheel Spacer Question
Old Apr 20, 2007 | 12:30 AM
Rob Willis's Avatar
Rob Willis
Default Wheel Spacer Question
Is is safe to run the stock lug bolts with a small spacer, say 4-5mm (~.19").
Also, where is the best place to grab spacers? I see them on Ebay, JEGs, etc. Do I really need DRM or fancy expensive ones that are this small?
Old Apr 20, 2007 | 01:00 AM
NewC6Toy's Avatar
NewC6Toy
I'd probably take this over to the wheel and tire section... Luke (Tire Rack) would probably have an answer.
Old Apr 20, 2007 | 09:36 AM
excessive81's Avatar
excessive81
i ran 2.5" with stock lugs and 400 rwhp with no issue until i got my new wheels. they on my blazer now front and rear and we beat the hell out of that thing off roading....no issue. just tighten bolts to 90-100 ft lbs like they say to or you WILL lose lug nuts!!!
Old Apr 20, 2007 | 01:48 PM
SpinMonster's Avatar
SpinMonster
This guy is asking if he can place a .2" spacer on the same lugs which takes away from the ability to get enough threads on the lugs holding the wheel on. You must have used adapters if they were 2 1/2" (even though it was 4.75 lug pattern to the same lug pattern) he is asking about spacer.
Unless that was a typo and you used a .25 spacer. Please clarify. The lugs on the rear arent 2 1/2 inches long and therefore can use a spacer that thick.
Old Apr 20, 2007 | 02:00 PM
99FewteRC5's Avatar
99FewteRC5
I am using spacer on the rear of my car. Its less than 1/4" thick with standard lugnuts with no problems. You can get them from any parts store.
[URL=""
Old Apr 20, 2007 | 05:08 PM
AU N EGL's Avatar
AU N EGL
How many threads does that lug nut grab on the stud?
If your drag racing I would suggest ARP hardened studs. That is what most of the road races run or with any spacer, plus open ended hardened lug nuts without caps on the lug nuts
Old Apr 25, 2007 | 11:23 AM
Rob Willis's Avatar
Rob Willis
Finding 4mm (not 3 or 5) spacers in 5x4.75" has become harder then I thought.
Hmph...
To Wheel Spacer Question
