Popping from rear differential
Old May 6, 2007 | 06:25 PM
rhoward2's Avatar
rhoward2
Default Popping from rear differential
Had the friction additive and new gear lube done about six weeks ago; now the noise is back. Do you guys recommend the new clutch packs? Is anything in there going to be harmed if I do nothing. Has anybody heard of solving the problem permanently with an aftermarket gear lube? Thanks in advance for any input you can provide.
Old May 6, 2007 | 06:46 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Before letting the dealer disassemble your car, try adding another bottle of GM friction modifier to your diff. (part number 1052358)
This made my rear silent after 2 drain and flushes failed to solve the problem.
And yes, my car still leaves 2 very black strips of rubber when doing a burn out.
Tom
Old May 7, 2007 | 04:47 PM
Vetteinplano's Avatar
Vetteinplano
If it's still under warranty, let the dealer fix it.
They did the additive "fix" first and then replaced the rear diff.
Had a trailblazer as a loaner vehicle for 8 days.
Old May 8, 2007 | 05:26 PM
rhoward2's Avatar
rhoward2
It took the dealership eight days to replace the clutch packs in your rear differential?
Old May 8, 2007 | 05:56 PM
VET4LES's Avatar
VET4LES
Have the dealer fix it. That's what a warranty is for.
Old May 8, 2007 | 11:21 PM
Vetteinplano
Took it in on a Monday, diagnosed problem, ordered entire rear diff assembly, received it on Thursday, finished it on Monday. Picked it up on Wednesday.
There were 4 others in there getting the same treatment.
Old May 9, 2007 | 08:52 AM
Zred06's Avatar
Zred06
Way back when I had my C6 Z51, I had it to the dealer twice for the same thing, the first time they did the GM fix of drain and additive, the second time they put a synthetic fluid in the rear and no problem. I don't remember what it was but I think it was something other than the GM fluid. If all else fails, buy a Z06, you won't have that problem.
To Popping from rear differential
