Installing an O2 Sensor Bung
Old May 13, 2007 | 07:27 PM
mfinocc's Avatar
mfinocc
Default Installing an O2 Sensor Bung
Is there an O2 Sensor Bung that can be installed without welding? Maybe one that would tap in?
Old May 13, 2007 | 08:24 PM
see5's Avatar
see5
Never heard of such a thing. You can use the rear post cat position.
Old May 13, 2007 | 08:35 PM
glennhl's Avatar
glennhl
You should be able to get a muffler shop to weld one in pre cat for pretty cheap.
Also, some people have told me that the post CAT location is fine for getting A/F ratios. Is this true? It would seem that the CAT would mess up the O2 readings, but according to one of the local dyno guys they've measured pre and post CAT without any differences.
Old May 14, 2007 | 02:13 PM
haljensen's Avatar
haljensen
Previous posts here said .6 to .7 leaner post cat, my Dyno shop said aprx. .3 leaner post cat, they've run both a wide band pre cat and a tailpipe sniffer on the same car.
Tailpipe sniffer showing 13.0 AFR = 12.7 AFR pre cat.
Old May 14, 2007 | 04:24 PM
glennhl's Avatar
glennhl
If that's the case then I'm running a bit rich. Thanks for the info.
Old Jan 29, 2008 | 08:06 PM
Jimmyz28's Avatar
Jimmyz28
What is the typical cost for installing a WB O2 bung pre-cat on a LT header collector? Is $100 expensive?
To Installing an O2 Sensor Bung
