Light replacement on C6
Old May 16, 2007 | 12:20 PM
topbackZ51's Avatar
topbackZ51
Cruising
Default Light replacement on C6
I purchased the stealth corner bulbs. and I am having a terrible time getting the stock lights out from behind the service flap in the inner fender. I know this sounds stupid, but does anybody have any tips on making this easier. Thanks in advance
Old May 16, 2007 | 02:10 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Not sure exactly what you having problems with. On the front side markers, once you have the service cover removed, gently press on the retaining clips and they will just pop out. Or just leave the reflector in place and twist the bulb holder out and replace the bulb. Rears work the same way but easier to go in through the rear tail lights.
Does this help?
Old May 16, 2007 | 02:21 PM
aTX427
Guest
Posts: n/a
Try using a screw driver to push on the tab while you twist the bulb.
Old May 17, 2007 | 01:24 PM
Buster1's Avatar
Buster1
I did the same mod a while back...it was tough. I can't remember exactly, but there are some stupid retaining clips you have to get out of the way before you can twist off the bulb. I seem to remember the screwdriver helping some.
Old May 17, 2007 | 01:36 PM
Gene Gorman's Avatar
Gene Gorman
I did the same thing. It sure helps to take the frot wheel off so you can see what you are doing.
Old May 17, 2007 | 10:41 PM
Dinger2u's Avatar
Dinger2u
Here is a link to a DIY I wrote regarding this very issue. Hope it helps.
http://forums.corvetteforum.com/show....php?t=1665253
Old May 17, 2007 | 11:14 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Old May 18, 2007 | 06:10 AM
timd38's Avatar
timd38
Have a person with small hands do it for you. I can not believe how tough it is to get your hand in there.
To Light replacement on C6
