Fob Problem
Old May 16, 2007 | 03:14 PM
Bowtie Junkman's Avatar
Bowtie Junkman
Cruising
Default Fob Problem
OK .... SO I GO OUT TO THE CAR THIS A.M. AND THE DOOR WON'T OPEN. HIT THE 'UNLOCK' BUTTION ON THE FOB, NOTHING HAPPENS. PUSH IT LIKE 50 TIMES, HOLD IT TO MY CHIN, STAND IN THE FRONT OF THE CAR, THE BACK OF THE CAR, OVER THE ROOF .... FINALLY THE LIGHTS FLASH AND I OPEN THE DOOR. I GET IN, CLOSE THE DOOR, PUT MY FOOT ON THE BRAKE, PUSH THE BUTTON ... IT CKLICKS A FEW TIMES AND NOW IT TELLS ME 'NO FOB DETECTED' ..... NOW I'M LOCKED IN THE CAR. I PULL THE 'EMERGENCY SHOOT' HANDLE AND THE ALARM STARTS BLAIRING (NOT GOOD IN THE GARAGE AT 6:30 A.M.) .... I RUN UPSTAIRS TO GET THE SECOND FOB. bY THE TIME i GET BACK DOWNSTAIRS TO THE GARAGE, THE ALARM QUITS. NOW I HAVE BOTH FOBS, AND NEITHER ONE WILL WORK. JUST CLICKS AND CONTINUES TO TELL ME 'NO FOB DETECTED'. HAVE TO DRIVE MY DAUGHTER'S COROLLA TO WORK (THAT BLOWS). CALL THE DEALER AND HE SAYS 'NEVER HAVE BOTH FOBS IN THE CAR AT THE SAME TIME', AND PLUG IT INTO THE GLOVE BOX AND SEE IF IT WILL START THAT WAY. ANY BODY HAD THIS PROBLEM SO I KNOW WHAT TO LOOK FORWARD TO WHEN I GET HOME ????????????
Old May 16, 2007 | 04:48 PM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
i can hear you, so stop yelling.
why wouldn't both fobs dye at or near the same time. didn't you get both of them at the same time? did they come off two different assembly lines. chances are the battery in the fob is same age or pretty close in both.
now that does suck, having to drive the corolla.
no fobs detected set the alarm ?
Old May 16, 2007 | 06:29 PM
VET4LES's Avatar
VET4LES
I would replace the batteries in both FOB's to eliminate that a possible problem. I had to replace one of mine about a year ago for my 05.
Old May 16, 2007 | 11:42 PM
johnodrake's Avatar
johnodrake
Moderator
You need to complete your profile so we will know your year/model. It will help folks give you help when you ask.
Old May 17, 2007 | 12:30 AM
torquetube's Avatar
torquetube
With both fobs on the blink, your problem is most likely radio interference, possibly from malfunctioning equipment nearby.
Switch off the circuit breaker for the garage door opener and see if your fobs start working reliably.
Old May 17, 2007 | 01:15 AM
haljensen's Avatar
haljensen
Lose the "CAPS LOCK" and try what the Dealer suggested. FOB in the glove compartment slot. Then find out what is interferring with the radio signal between the FOB and the reciever in the car. Do you have a cell phone or cell charger in the car? Door opener transmitter? Anything attached to your sound system? Alarm added to the car?
The Dealer is wrong about both FOB's in the car, it works.
Old May 17, 2007 | 06:53 AM
pedalpusher's Avatar
pedalpusher
I had the same problem. In my case the problem was the antenna and/or the receiver that are located under the dash. I know there are other antennas but it was decided the one under the dash was suspect. Both were replaced and the problem is gone. Since they decided to replace both, I do not know if both failed or just one. The tech felt is would be the receiver.
Old May 17, 2007 | 03:52 PM
calemasters's Avatar
calemasters
Some people have had to push the car out of the garage before in will start. In some cases it was RFI from the garage door opener reciever.
Old May 17, 2007 | 04:36 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
That's from your dealer. My wife and I have both fobs in the car all the time (she keeps her's in her purse).
Old May 17, 2007 | 05:58 PM
torquetube's Avatar
torquetube
That was the problem in my case.
Of all the places in the world to have a source of radio interference that prevents starting the car...
To Fob Problem
