Rear axle nuts
Elmer
Elmer
FYI, the 1-5/16 is almost exactly halfway between a 33MM and a 34MM, but glad you managed to get the second set on the axle...it won't come loose again I'm sure!
He now says he will check every c6 that comes in, but I don't think the dealers care enough - unfortunately - to be proactive about this. Has to come from the General itself.
A good idea is if someone on the forum has any connections at all with an appropriate GM employee; e-mail or fax or snail mail them this list ASAP.
They should be made aware of it and it should be documented well. Then if someone does have a mishap due to this issue, perhaps a foundation for recompense will already exist.
Have any moderators posted in?
Your diagram shows the hub assy bolted to the "knuckle", sure enough. No matter what happens to the nut on the axle, and the axle itself, the hub assy (or the outter part of it anyways) is going nowhere; just like the diagram shows.
The problem is, your diagram doesn't show how the rear wheel bearing, and the actual HUB itself (the part that the wheel bolts to) is held into the hub assy, and preloaded. If it's like other GM products of similar design, the tightening of the axle nut sets and holds the preload of the wheel bearing. It also holds the hub, into the inner race of the bearings in the "hub" assy. With the nut gone, the bearing is free to work loose over time, eventually come out of the hub, and then the wheel comes off. That is why you get posts like these:
Granted it's going to take a LOT of aggresive driving to get the PRESSED bearing to come apart, but it sure can. And granted it will make some hellish sound before it comes apart, but it can.
