Electric Water Pump
Old May 18, 2007 | 01:53 PM
whayes's Avatar
whayes
Default Electric Water Pump
Thinking of adding a Meziere electric water pump. What are the pros/Cons? Any performance Gains? What accessorybelts and source?
Old May 18, 2007 | 08:51 PM
kelp's Avatar
kelp
Not for sustained power output.
Old May 19, 2007 | 01:33 AM
Bahnzii's Avatar
Bahnzii
You lost me on this one???
Do you mean you wouldn't use one if you were doing sustained high rpm work, i.e. road racing??
And if so, why not??
Or did mean something else and if so, what??
Please enlighten us, as I am also considering this option on my C6
Old May 19, 2007 | 02:02 AM
kelp's Avatar
kelp
Oh ok I thought it was self evident. I was once interested in these things. Historically these were good for dragsters, then they spread around to daily drivers to get a few more HP. Now they're hitting the performance market - it's not working. I admit it looks good on paper. Problem is even if the pump had the same GPM, it can't push against the same resistance. Try one out. Put your hand up to block the output and see. The majority of reports I have read from people returning to stock water pumps are road racers who get overheating problems after a time. Then there are the sudden failure stories. No warning.
I remain interested in electric water pumps, they make some sense to me. Just that, they're pretty expensive and still need improvements.
Old May 19, 2007 | 11:31 AM
tjwong's Avatar
tjwong
Why would you want to replace a perfectly good water pump for a electric job that is expensive? You will not realize much gains in terms of power, and as for reliability for sustained use, that would be a problem for me. Look at it this way, you are away from home on a road trip, you have a pump failure, where do you think you are going to get a new pump? I doubt many shops would keep one on the shelf. My warehouse which is a major distributor of performance parts don't even stock one. Now if you have a stock pump, you will find that almost anywhere.
Old May 20, 2007 | 08:12 AM
EuroRod's Avatar
EuroRod
I'm running the Meziere. Two reasons: It runs at a consistant output, not tied to the rpm of the engine. If you toss a belt (also running a ProCharger) it will get you home. I've had zero issue with it. Works as advertised.
oh, and it's good for 6-8 hp at the top end.
Old May 20, 2007 | 08:25 AM
SickRick's Avatar
SickRick
to a point. Had to replace my stock pump, only no one had one in stock. 1-2 days away. Ended up replacing with a 3K mi "take off" from someone who just put an electric in at the shop I use.
The main benefit of the electric is to reduce the drag on the serpentine from driving the water pump. The other upside is you can still cool the car with a thrown belt and get it home/to the shop.
While interesting in theory - as mentioned above - reduced output at high RPM's (it's a single, not variable speed pump), and the risk of failure without available replacement kinda steered me away from it.
My interest comes from the fact that my maggie at full boost puts a SERIOUS load on the belt (30HP +/- according to magnuson), which I believe to be the contributing cause of failure to my original pump (@ 62K mi - leaky seal). I'm still kinda interested, but due to the factors noted above, not enough to replace the belt driven one...
Rick
Old May 20, 2007 | 09:00 AM
valdeztke's Avatar
valdeztke
$$$$$$ not I said the poor man
Old May 25, 2007 | 12:09 AM
Abomination's Avatar
Abomination
I had a Meziere installed on mine and I love it. You asked for pro's/con's. so here they are.
Pro's.
5-10 hp depending on the RPM's, higher RPM = more hp
The car stays alot cooler, thru the summer the stock C6 was hitting deep into the 200's (vegas heat is a biotch). Now with it 120 outside and me beating up the car it just hits 200. The second I stop and idle it drops to the 190 range.
Easier to tune, the car cools down so much quicker with the high rpm electric motor going at full throttle when the car is at 800 rpm's. Instead of waiting 20 minutes between pulls or worrying about heat sink you can almost go back to back runs on the dyno. My tuner loves me lol.
Con's. Cost, its not a cheap 5hp.
Can get the car to cool. When the winter hit here in vegas I started throwing a CEL. It was my fault because I didn't change the water wetter in the winter but either way the combo of the pump and WW was running the car so cool the CEL was popping on because of emissions.
Basically I love the water pump but I would do all the other bolt-ons first. I would only recommend the pump for someone that has FI, H/C or every bolt on in the book.
Old May 25, 2007 | 10:29 AM
SpinMonster's Avatar
SpinMonster
Drag racers also love the car-off-with-pump-running feature.
As for the power, www.LS1howto.com showed a dyno'ed 6hp gain.
The best is the pretty factor. There are guys that pay more than 600 bucks just for ugly chrome covers and beauty tweaks under the hood. I cant see how in a world of 1000+ exhaust systems that do nothing for power that its ok to justify exhausts for noise and not a water pump for beauty and 6hp.
If you live on the hiway, pack the stocker, pliers, and a 10mm rachet.
Old May 25, 2007 | 06:58 PM
Abomination
I'd love to hook up the electric fans and the water pump to a switch inside the car so i can let it run full blast while the car is off. Would be great at the track
:edit: Anyone know how to do this?
Old Jun 25, 2007 | 08:51 AM
VetteRobbie's Avatar
VetteRobbie
Default I switched back to my stock pump
I installed a Meziere pump on my 07 Z06 with a 160 degree thermostat. Simply stated, it won't keep the engine cool under stress. That is to say, if you are driving in 5th at 60 mph your at 170 degrees. Anything else, it creeps up into the 180s and 190s. That's with the outside temp in the 70s. I am afraid to take it to a road track, so, being very disappointed, I am replacing my stock pump with a 160 thermostat. We'll see. It was a total disappointment and waste for me.
VetteRobbie
Old Jun 25, 2007 | 10:41 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Electric water pumps typically run at one speed, ~2500 RPM and that's also max flow. Consequently, fixed speed pumps like this are thoroughly ineffective at higher RPM's.
Additionally, and this comes from Evans Cooling, the typical flow of electric pumps are about 40% of that needed to manage engine speed above 5k RPM and worse above that.
VetteRobbie
Old Jun 25, 2007 | 11:00 AM
LloydP's Avatar
LloydP
Depends on what you plan on doing. From a mechanical ennginering point of view, it doesn't seem to make sense.
I don't have a pump curve but I would bet that the stock pump is a compromise. It needs to be large enough to cool at low RPM but that makes it too large at high rpm. The oversize shows up at high rpm as inefficiency and lost HP.
The power consumed by the electric pumps will be constant. If you total up the losses in converting mech energy to electrical then back to mechanical the total power consumed at crusing RPM will be higher than with a mechanical pump.
At high RPM, you are avoiding the losses in overspeeding the mechanical pump, giving you 6 hp.
Considering the cost and increased complexity, it seems like a poor tradeoff for normal driving.
Old Jun 25, 2007 | 11:30 AM
xs650's Avatar
xs650
except the stock pump is a better match to reality than that. Engine heat rejection is roughly proportional to power output and power output at full throttle is roughly proportional to RPM. Mechanical pump flow is reasonably proportional to RPM, so it's a decent match.
Unless water pumps have improved a lot in the past decade or so, there is a lot of room for improvement in automotive water pump efficiency. That could yield some power savings without hanging a bunch of electrical pump clap-trap on an engine.
Old Jun 25, 2007 | 11:50 AM
LloydP's Avatar
LloydP
Concur: Too many negatives to discuss in one post.
Old Jun 25, 2007 | 12:40 PM
cbrf4i1's Avatar
cbrf4i1
there is no free lunch....at least not on this one.
http://forums.corvetteforum.com/show....php?t=1740094
http://forums.corvetteforum.com/show...post1559049189
Old Jun 25, 2007 | 03:38 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Agree with all said previously. My car is in for a H/C package as we speak. All the guys at CARTEK talked me out of one because of all the above. The biggest Pro as Spin said is cooling between runs at the track when the motor isn't running. The biggest con is abrupt and unpredictable failures @ about 3,000 hrs give or take. Have an elec water pump crap out when you're on the road and you're 2 days or so getting back together. The solution to that is to carry a spare pump. Not out of the question but is it worth all that?
Old Jun 25, 2007 | 03:55 PM
Abomination
I've had nothing but a positive experience with my pump. I've had it on for about 7500 miles and it works perfect. I've had my car (dark color) idling at a dead stop on the freeway in 115 degree weather for an hour with the A/C full blast and the car never was over 200.
On the other hand with my mechanical pump in stop and go traffic when it was about the same temperature the car was hitting 235
I've had the car on a road track and the 1/4 mile (granted 1/4 was at night but it was still 100 degrees here) and again the car never even hinted about overheating.
I do enjoy reading everyones logical arguments on why they don't work but here I am a year and a half later with nothing but good things to say about it driving in the hottest part of the country daily.
To Electric Water Pump
