Air Filter shroud on or off
Old May 18, 2007 | 05:00 PM
Angelo C6's Avatar
Angelo C6
Default Air Filter shroud on or off
I'm going to the track tonight and I was wondering if the stock air filter set-up is restricted when the plastic shroud is over the air filters. There does not appear to be a ton of room for air to pass with this cover. Does this cover do anything other than keep water out of the filter? Should I take it off for the track?
Old May 18, 2007 | 07:04 PM
Whiterock1's Avatar
Whiterock1
Push it back 3" with props. Simple to do, and then only cold outside air comes in thru the grill.
Old May 18, 2007 | 08:01 PM
VET4LES's Avatar
VET4LES
I think Angelo C6 is talking about the cover on the top of the filters. It's there to keep the water out. It's OK to take it out if it's not raining but I would put it back when your done racing. I took mine out and when I washed the car the filter boxes both had about a 1/4" of water in them.
Old May 18, 2007 | 09:54 PM
Angelo C6's Avatar
Angelo C6
Thanks guys, just got back from the track. Left the cover on but propped open the shroud below. Used two small pieces of 2x2 with hole drilled through. Ty-wrapped the blocks into the original fastener holes and done. 10 minutes work. Car ran great, 2 pieces of wood are the only mod. 05 vert A4 3.15 F55 ran 12.72
Old May 19, 2007 | 11:09 AM
Whiterock1's Avatar
Whiterock1
Great times! And zero dollar mod! The cold air thru the grill really does add power.
To Air Filter shroud on or off
