Transmission Gear Ratios
Old May 23, 2007 | 02:11 PM
07 Z51's Avatar
07 Z51
Default Transmission Gear Ratios
Does anyone KNOW the gear ratios, 1st gear through 6th gear, of the regular transmission and the Z51 transmission? If so, please post......
Old May 23, 2007 | 03:42 PM
glass slipper's Avatar
glass slipper
From the C6 Z06 FAQ post #9:
http://forums.corvetteforum.com/show...35&postcount=9
Old May 24, 2007 | 07:40 AM
07 Z51's Avatar
07 Z51
Thanks. Should have thought to look there. Don't mind the FNG.......
Old May 24, 2007 | 08:20 AM
glass slipper
No problem, welcome to the Forum! It's a great place to get info on just about anything. You'll get more familiar with navigating the Forum the more time you spend here. In particular, the search function at the top right of the page. Open it up and click on "advanced search" and you can search for anything you want. There's an option at the bottom right of the advanced search page that let's you search in current (open) threads or archived (closed) threads. Make sure you search the archived threads as the "current" threads get closed after 3 months of inactivity. So there's a ton of info in the archived section.
Old May 24, 2007 | 03:05 PM
andreas g.'s Avatar
andreas g.
Here they are;
Z51 1st - 2.97
2 nd-2.07
3rd- 1.43
4th- 1.00
5th- 0.71
6th- 0.57
Standard and Z06
1st- 2.66
2nd-1.78
3rd- 1.30
4th- 1.00
5th- 0.74
6th- 0.50
To Transmission Gear Ratios
