Front End Curb Scrapper
Old May 29, 2007 | 02:26 PM
cargeek's Avatar
cargeek
Default Front End Curb Scrapper
I would love to get rid of the vertical piece under the front end that scrapes on driveways and gets scratched up.. has anyone done this...Thanks..Doug
Old May 29, 2007 | 02:30 PM
SS502MC's Avatar
SS502MC
It is there to direct the airflow. I would not remove it. I think it is the lowest cost part on the car, so if it gets too ugly for you replace it (40-50$) if I remember.
Old May 29, 2007 | 02:43 PM
AintQik's Avatar
AintQik
Yas got to have that in place to direct air over the radiator. In these cars, as well as Fbodys and others the rads have to be in there at an angle. This combined with the smaller front area of todays cars, makes it hard to get enough air over the rad to keep her cool. The deflector is there to get air to the radiator.
On a practical note, I hade a trans am that got some body work done. The guys forgot to put the curb scraper back on and the car ran really hot. Kind of like it was standing still. I was concerned then looked under there and noticed it missing. Just think of it as a early warning system. My car is slammed and I pretty much use it to sweep the street.
Old May 29, 2007 | 06:42 PM
User 81424's Avatar
User 81424
It also serves as an air dam to reduce front end lift.
Old May 30, 2007 | 12:35 AM
haljensen's Avatar
haljensen
The air dam is a designed part of your cooling system, it creates negative pressure behind the radiator.
Old May 30, 2007 | 01:09 AM
Wayne O's Avatar
Wayne O
CF Senior Member
The deflector is there for a purpose but if you keep scraping it you'll get rid of it soon enough.
Old May 30, 2007 | 01:38 PM
Buffy's Avatar
Buffy
I believe the C6 is designed for 80% front / 20% bottom breathing, so removing the air dam probably won't hurt the cooling that much. The F4 was essentially 100% bottom breathing, it really needed the air dam to direct air to the radiator.
In any case, its in 3 pieces: (left, middle and right), held together by plastic push-in fasteners and held onto the car by about 10 7mm hex head screws. Not hard to remove - or re-install.
However, I wouldn't drive car over 200 KPH (120 MPH) without it, as it is an important part of the undercar aerodyamics and high speed stability will be adversely affected.
Old May 30, 2007 | 10:17 PM
AintQik's Avatar
AintQik
So a 20% loss in cooling is ok? Um I'll take the 100% thanks.
Old May 30, 2007 | 11:14 PM
runutzzzzz's Avatar
runutzzzzz
Do you guys think we can trim it so it doesn't scrape but still maintain the cooling properties?
Old May 31, 2007 | 10:36 AM
Vetteinplano's Avatar
Vetteinplano
Out of curiosity, can you tell us where you found the information of the 80/20 rule?
Old May 31, 2007 | 12:55 PM
Buffy's Avatar
Buffy
I recall the 80% / 20% figure from an article on the development of the C6.R, they were talking about one of the things that they'd asked for in the C6 was front breathing. But I can't find that now, and what I can find is from the original C6 preliminary info, which says 60% / 40%. So either I read or remember it wrong, or (as often seems to be the case) there are two sets of figures floating around.
The 60% / 40% quote can be found at http://www.corvettemuseum.com/specs/2005/design.shtml - look for the quote ".. C6 switches from the 100 percent bottom breathing air intake of C5 to a hybrid air intake of 60-percent front/40-percent bottom."
If I find the other article again I'll post it. Or maybe the only way to know for sure is to measure it.
Old May 31, 2007 | 01:55 PM
AintQik's Avatar
AintQik
Just scape it. They are pretty tough and you cant see them. It scrapes, so what? I know its scary at first but if you keep thinking its just that dumb $40 plastic thing it all get s better.
Old May 31, 2007 | 02:22 PM
805Z06's Avatar
805Z06
I know somebody who races his modified Z06, he removed it (or it broke off at the track and he never replaced it. He told me that it helps with the downforce, but that's mostly usefull at very high speed.
It's really easy to remove, give it a try for a couple of weeks, you could always put it back up..
Old May 31, 2007 | 02:32 PM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
My still functions perfectly after running over a dead dear at 85mph that was laying across my travel lane.
Old May 31, 2007 | 02:40 PM
fenderowner's Avatar
fenderowner
It's expected to scrape (see owner's manual, "Starting and Operating Your Vehicle," page 2-21 in the 2006 manual). Once you know that, you just learn to live with it, as it's not hurting anything. HTH.
Old May 31, 2007 | 04:58 PM
dkluko's Avatar
dkluko
I left my middle portion on but removed only the sides. That help me not scape so much. on turns, which is where most of it was happening anyway.
Old May 31, 2007 | 05:57 PM
haljensen's Avatar
haljensen
I have no idea how important the air dam is on the C6 but do know it was VERY IMPoRTANT on previous cars and trucks. Without th air dam the vehicle overheated, with it the vehicle ran at normal temps. Since all the C6's are relatively new and most of my previous car weren't it could be a factor of age of the coolant and cooling system.
The Chevy engineers/designers wouldn't spend the time developing the part if they didn't think it was required.
To Front End Curb Scrapper
