Clutch pedal spring; Final verdict?
Old Jun 1, 2007 | 12:27 AM
Brett Hunter's Avatar
Brett Hunter
Originally Posted by cbrf4i1
i respectfully disagree. if you have the spring out try putting it back in. you will notice it is impossible to put it back on if the clutch pedal is all the way up, i couldn't even stretch that spring that far even using a screw driver as leverage. now have someone push the pedal all the way down and then try to put the spring back, you will see you wouldn't have to stretch that spring that much compare to when the pedal is all the way up.
does someone have a picture of c5 & c6 spring side by side they can post? thanks
If you have your spring removed try the test I described in the post above.
When I changed the master cylinder on mine the spring held the pedal up. It only effects the last inch or so of travel but it does hold it up.
Old Jun 1, 2007 | 12:47 AM
cbrf4i1's Avatar
cbrf4i1
something held up your pedal, what i don't know since i wasn't there. if you were to try what i suggested you will realize there is no way the spring was holding up your pedal. with the pedal in the up position, the spring is getting stretch the most from it's relax state.
http://forums.corvetteforum.com/show....php?t=1608505
http://forums.corvetteforum.com/show....php?t=1481786
Old Jun 1, 2007 | 01:43 AM
sallen619's Avatar
sallen619
I've had mine off for over a year.... I like it.
Old Jun 1, 2007 | 05:23 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Originally Posted by Minkster
Dealer is where I got mine.
Anyone have a part#
Old Jun 1, 2007 | 05:31 PM
drfeelgood's Avatar
drfeelgood
Default No spring A-ok
I've had the spring off my 2005 for over a year without any negative issues. Definitely a better clutch feel without the spring.
Old Jun 1, 2007 | 06:27 PM
Minkster's Avatar
Minkster
Originally Posted by k0bun
Anyone have a part#
According to my receipt:
12555205
Old Jun 1, 2007 | 06:52 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Anyone have the C5 spring part number?
Old Jun 1, 2007 | 09:18 PM
johnodrake's Avatar
johnodrake
Moderator
Here you go shipmate: 12555205
I just checked it at www.gmpartshouse.com and it comes up correct.
Old Jun 1, 2007 | 11:37 PM
xs650's Avatar
xs650
The spring can hold the pedal up near the top of the stroke and help keep it down near the middle and bottom end of the stroke.
It's done by laying out the geometry so that the spring goes over center during it's stroke. Some short distance from the pedal up position, the action line of the spring is through the clutch pivot and it exerts no up or down force on the pedal. Above that position it lifts the pedal, below that it tries to pull the pedal down.
A spring is needed to pull the pedal to the top because if the master cylinder isn't fully retracted, the reservoir stays shut off from the hydraulic circuit. This can cause problems.
A weaker spring is a better long term solution than no spring.
Old Jun 1, 2007 | 11:44 PM
cbrf4i1's Avatar
cbrf4i1
perhaps this in theory could work, but it doesn't apply to our c6. if you were to try to put the spring back in with the pedal all the way up, you will discover the truth about if this spring does pull the pedal up or not.
Old Jun 2, 2007 | 07:53 AM
foliva's Avatar
foliva
I'd be interested in installing the C5 spring. I've heard it's easy to remove the existing spring, but difficult to install the new spring. Does anybody have a procedure to install the new spring?
Old Jun 2, 2007 | 08:08 AM
cbrf4i1's Avatar
cbrf4i1
yes it is very easy to remove the spring, it takes me like 5 sec. putting the spring on, you best bet is to have the pedal all the way down, so the spring is getting stetch the least / easier to put on. leave the pedal all the way up would be the hardest way to put the spring back on.
Old Jun 2, 2007 | 04:16 PM
  #33
NIGHTSTALKER's Avatar
NIGHTSTALKER
Ordered my C5 spring last night. I can't wait to feel the difference. The clutch engagement is my only complaint about these cars....Feels to much like ON/OFF if you ask me.
Old Jun 2, 2007 | 07:01 PM
  #34
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Half my spring broke like 3 months ago while was driving. The other half is still intact. My question is, "To change it over to c5 spring" will the dealer install one on the c6?
Old Jun 3, 2007 | 03:19 PM
  #35
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Many Thanks Shipmate
Old Jun 3, 2007 | 09:15 PM
  #36
crabby's Avatar
crabby
St. Jude Donor '06
I had the C5 spring laying around for a few weeks, and this thread reminded me that I had not done it. As was mentioned, with the clutch on the floor, the original can be popped out in a few seconds. Putting the lighter C5 spring in was a bit more of a project. I finally got a bit of brain going and wired the loop end that fits into the notch at the rear of the clutch pedal arm down temporarily so that it could not slip out while reinserting the tips into the holes in the assembly frame. It helped a lot. And, in my humble opinion, it is so much improved as to be unbelievable. Totally smooth with much better control.Thanks for the suggestion.
Old Jun 4, 2007 | 02:33 AM
  #37
THECRAIGMEISTER's Avatar
THECRAIGMEISTER
Taking out the clutch spring was such a huge improvement!! I am skeptical but may try the C5 spring. If it works well I will leave it and if not it will come out as well!
To Clutch pedal spring; Final verdict?
Old Jun 4, 2007 | 11:06 AM
  #38
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Originally Posted by 6 speed Sid
My clutch does feel a little "grabby". I wish it was smoother on engagement.
Mine was too. After 27k miles it's smooth. I started to notice increased smoothness @ 5-7k and gets better all the time
Old Jun 4, 2007 | 11:07 AM
  #39
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Mine broke 1K miles ago. Feels mo betta.
Old Jun 8, 2007 | 11:26 PM
  #40
NIGHTSTALKER
Thats great to hear...Mine came in yesterday, and I will be installing it tomorrow.
