How can I read codes without a Tech II?
Old May 31, 2007 | 01:00 PM
vetracer's Avatar
vetracer
Default How can I read codes without a Tech II?
Is there any way to get code information out of a C6 without spending thousands of dollars on a tech II tool?
I have a custom tune (Ls2 Edit) but don't want an Ls2 Edit programmer. I may go HP Tuner down the road. Any suggestions? I'm getting a "service charging system" on the DIC.
Old May 31, 2007 | 01:47 PM
Mike L.'s Avatar
Mike L.
A handheld like the Predator can read and erase codes. These sell for like $400 new, but even a locked used unit would be a great code reader and allow you to view real time data as well.
Mike
Old May 31, 2007 | 01:51 PM
AintQik's Avatar
AintQik
Go to Advance Auto part or Autozone. Free. Oh, by the way what mods do you have on the car? I get the same message and it was never there before. I had an under drive pulley and it was fine before but now I have to pop the throttle to make that message go away. I think it is because the battery is weak. Also, don't bother pulling codes, it will just tell you the same thing that the DIC is telling you in this case. I pulled mine with HP and all it said was the same thing in differnet words.
Old May 31, 2007 | 01:52 PM
VET4LES's Avatar
VET4LES
You can buy CAN enabled code readers for $75 and more at Wal Mart and auto parts stores. Their are many good ones available. Check out the features on line and buy the one that's suits your needs. I have a Innova 3110 that I like. I paid around $160 for it.
Old May 31, 2007 | 03:25 PM
vetracer's Avatar
vetracer
I do have an underdrive pulley. Don't waste your money on a new battery, I put a new Optima in mine last night. Same code coming on today. Funny thing is not only do I get it on startup but I still get it intermittently when the car has been running for a while and the volts are over 13. The manual says to hit the reset button when you get a display on the DIC. Doesn't seem to do squat, though.
Old May 31, 2007 | 04:05 PM
Miaugi's Avatar
Miaugi
Originally Posted by VET4LES
You can buy CAN enabled code readers for $75 an more at Wal Mart and auto parts stores. Their are many good ones available. Check out the features on line and buy the one that's suits your needs. I have a Innova 3110 that I like. I paid around $160 for it.
...try to get the latest in the 3100 series...it is 3100A. BTW, I'm sure you don't want to cough up for a Tech II...they sell for about $2K.
Old May 31, 2007 | 06:08 PM
haljensen's Avatar
haljensen
If you buy a code reader/resetter make sure it's OBD2, CAN enabled or you'll only get partial information.
Old May 31, 2007 | 06:12 PM
C6Brian's Avatar
C6Brian
Yes they will scan it for you, but they are NOT allowed to clear the codes....but money talks.
Old May 31, 2007 | 09:06 PM
vetracer's Avatar
vetracer
So if you don't clear it does it keep coming back regardless of whether or not the condition has been corrected?
To How can I read codes without a Tech II?
