Locked out
Old Jun 2, 2007 | 11:12 AM
mgdim's Avatar
mgdim
Default Locked out
battery dead and I think the key is IN THE CAR! Anyway to get the hood open?
Old Jun 2, 2007 | 12:22 PM
VET4LES's Avatar
VET4LES
You should have two keys. If you have a battery charger it is possible to jack the passenger side up and charge the battery from the starter motor battery cable. Good luck and let use know what happens.
Old Jun 2, 2007 | 12:42 PM
DP Dave's Avatar
DP Dave
Les,
You are "The Man!"
Old Jun 2, 2007 | 01:05 PM
mgdim's Avatar
mgdim
I don't have a charger, what about jumper cables?
Old Jun 2, 2007 | 01:29 PM
Abomination's Avatar
Abomination
Not sure about jumper cables but if you can reach the starter cable you can attach the negative jumper cable to the closest ground (header bolts ect) so you dont have to wiggle up into the car.
Also, the easier way imho is to goto the dealership with your vin # and have them cut you a key for 10 bucks. No chip in the key so quick and easy. Take some paperwork proving you own the car (insurance card, registration, contract ect ect)
Old Jun 2, 2007 | 01:32 PM
VET4LES's Avatar
VET4LES
It might work. It could be a problem hooking up the cables in the small space but it's worth a try. Some members have a problem with cables when their attached to the battery so it's not for sure. The cables should be 4 gauge or bigger for best results.
Old Jun 2, 2007 | 01:33 PM
VET4LES's Avatar
VET4LES
Originally Posted by DP Dave
Les,
You are "The Man!"
Thanks.
Old Jun 2, 2007 | 02:57 PM
jbergnes's Avatar
jbergnes
Default Emergency Entry Access System
Mid America Motorworks sells what they call EEAS. the cost is $29.99 and the install is quick. Their Item #634149. Basically you have a pair of
alligator clamps accessable under front bumper, I have tested it and works fine.
To Locked out
