snake charmer vs. honker
Old Jun 13, 2007 | 07:11 AM
nmk's Avatar
nmk
Default snake charmer vs. honker
I'm planing to put on a CAI, from what I have read the vararam snake charmer, and callaway honker both seem good. Is one any better than the other? Does anyone have 1/4 times, before and after? I'd just like to hear some real world numbers. Thanks!
Old Jun 13, 2007 | 07:29 AM
dennis50nj's Avatar
dennis50nj
12.91 before 12.38 after vara ram and spacer now 11.620 bolt ons
Old Jun 13, 2007 | 07:36 AM
andyandy98's Avatar
andyandy98
The Vararam, Honker and LPE seem to be the most popular here for sure. I think the differences with these three will be marginal, but that is based on all feedback I have read only.
It would stand to reason that at higher speeds the vararam has an advantage as air is forced into it's chamber which would help with faster processing of the new air, therefore breathing a little more and producing a few extra ponies. This would be the interesting measurement, along with drag times {using the exact same car in the exact weather conditions and only switching the CAI}.
What we really should know is how much additional air does the Vararam put through a C6 engine at WOT at 10, 30, 50, 75, 100 mph as compared with stock and the Honkers, LPE's, Halltechs etc. Then calculate measurable quarter mile run differences.
For me this is only a common sense perspective, I am not a racer or engineer. Just seems those measurements would provide the trur performance differences between these CAI.
Old Jun 13, 2007 | 07:42 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
LPE
Old Jun 13, 2007 | 08:06 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Go with the VaraRam.....
Old Jun 13, 2007 | 08:10 AM
Boston Z51's Avatar
Boston Z51
Just installed the generation 2 K&N "Fuel injection power kit".. The filter element is carbon fiber and its very well made. Includes a mounting bracket also that re-uses the stock air box gromets.. Most sites selling them for $340-$400 + shipping. Found a site that sold it for $297 free shipping!
Added 10RWHP and sounds great..
Also I wouldn't expect more then a .1-.2 change in 1/4 times with any intake unless your stock intake is clogged with leaves...
Old Jun 13, 2007 | 10:15 AM
fright88's Avatar
fright88
can you link me to this site?
Old Jun 13, 2007 | 10:33 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I have a Calloway. If I did it again I'd do VRAM
Old Jun 13, 2007 | 11:02 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Love my Callaway Honker. If I had to do it again, I'd still get a Callaway.
The build quality of that Vararam is what drove me away from it.
As for the Honker's quarter mile improvements look at this link
http://forums.corvetteforum.com/show....php?t=1328533
Old Jun 13, 2007 | 11:53 AM
VET4LES's Avatar
VET4LES
I bought the same one on e-bay for the same price shipped. Probably the same company. You can e-mail him at kirbancustoms@epix.net
Old Jun 13, 2007 | 04:09 PM
nmk's Avatar
nmk
for you guys that have the snake charmer what do think of the build quality? How was the install, did things line up the way they should ect.
Old Jun 14, 2007 | 12:01 AM
Guitarstar's Avatar
Guitarstar
Great Mod, Go Vararam.
Old Jun 14, 2007 | 01:16 AM
71stang99's Avatar
71stang99
The Vararam has good intentions however I was not the happiest with the quality, the directions were worthless, when I received it was packed in garbage sacks which normaly I would not care however the lower piece had the garbage bag stuck to where the upper and lower intake sealer was attached which required me to remove part of it to remove the plastic trash bag stuck to it, after installing I had to take off the top part and reseat the sealing strip on the lower intake so it lined up. Would I buy from again? yes however I think they would sell more units if they used better packaging and a tech writer knew how to take pictures and edit a simple procedure.
Old Jun 14, 2007 | 01:42 AM
glennhl's Avatar
glennhl
I have the Excelerator, the Honker knock-off. I just got back from a 1600 mile trip through a lot of crap in the Colorado mountains. I took the filter out tonight and it still looks very clean. I hear the Vararam really sucks up a lot of needles and junk (do a search). I am very impressed with this design plus I do not have to fear the hydrolock.
Old Jun 14, 2007 | 08:46 AM
andyandy98's Avatar
andyandy98
Good post Glenn, I have also heard the Vararam can act like a huge vacuum cleaner sucking in lots of unwanted materials.
I think the guys that order the vararam should strongly consider the race mesh grills in the empty space in the front bumper. At least that will further ensure that larger debris doesn't make it's way up to clog the filter.
Old Jun 14, 2007 | 05:22 PM
nmk's Avatar
nmk
come on guys make up my mind!
Old Jun 14, 2007 | 10:26 PM
rzone's Avatar
rzone
OK
Go with the Honker.
I did, the performance is very good, the look is near stock, and it is
from a company that knows Corvettes.
I think the VRAM is cool too, but it looks like sub par quality and Rube
Goldberg-ish looking hack. No doubt though that it probably performs
slightly better while picking up more debris.
Support a forum vendor.
Edited to add flame suit, this is a religious war...
VRAM = more performance
Honker = better looking and close performance
To snake charmer vs. honker
Old Jun 14, 2007 | 10:33 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
I have the Vararam and if i was to do it again, without a doubt i would get the VARARAM
Old Jun 14, 2007 | 10:47 PM
dennis50nj's Avatar
dennis50nj
i think i had one of the first vr and spacer. i have 22,000 miles about 16,000 just on the vr. never a problem i have hit puddles purposley to clean the bottom of the car from a trans line leak. i hit the deepest puddles at 80 mph no problems i have the original filter not the better green one. no problem the filter looks new i check it and bang it looks new. never oiled it and i have the fastest bolt on time 11.62. if your not into performance then dont get any filter leave it stock if you want the best bang for the buck vr and spacer
Old Jun 14, 2007 | 11:19 PM
Gman57's Avatar
Gman57
DON'T OVER LOOK THE VORTEX RAMMER COLD AIR SYSTEM! SOLID PRODUCT AND THE FOLKS AT BREATHLES ARE GOOD TO WORK WITH TOO........
