CEL, Code P0171
Old Jun 21, 2007 | 01:41 PM
EuroRod's Avatar
EuroRod
Default CEL, Code P0171
Friend of mine just installed a new intake manifold on his 2005 C6 and after two weeks of driving, it has thrown a P0171 (bank 1 lean) code. I said probable intake gasket failure, and it's sucking a little additional air, resulting in the lean condition. He says, "No way." He installed it correctly. Before we go tearing the manifold off, I thought I'd ask anyone here if they may have had a similar problem or code, and what remedy fixed it. Thanks.
Old Jun 21, 2007 | 01:48 PM
Z51 6spd's Avatar
Z51 6spd
Maybe the MAF got dirty?
Old Jun 21, 2007 | 01:53 PM
VET4LES's Avatar
VET4LES
I agree the gasket is the problem. If it's only bank one the problem will be something that affects only that bank.
Old Jun 21, 2007 | 02:17 PM
codename Bil Doe's Avatar
codename Bil Doe
Make sure he didn't disconnect anything else and to check all the clamps post-maf.
Old Jun 21, 2007 | 04:28 PM
cbrf4i1's Avatar
cbrf4i1
i am with you eurorod.
Old Jun 21, 2007 | 05:10 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
me too.
bank 1 lean and bank 2 lean
Old Jun 21, 2007 | 05:26 PM
Ranger's Avatar
Ranger
On LS1 and LS6 motors with a CAI installed, occasional P0171 and P0174 codes under very light throttle are reported routinely.
The advice is:
Check all the connections in the airpath for tightness. Clear the code(s) and go for a ride. It's very rare for the code to recur on the test drive.
I used to get one or the other lean code a couple times a year on my 2002Z with CAI, always a minimal throttle when descending a long grades once the speed had dropped to 30-35 in 5th.
It never reflected a true lean condition of concern.
Don't know about a CAI on the LS2/7. Mine is stock.
Ranger
Old Jun 21, 2007 | 05:31 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
The advice is:
Ranger
Ranger, help me out please!
"P0016" Crank Shaft Position - CamShaft Position Correlation - Bank 1
what is that? I also got "UNKNOWN" code!
Old Jun 21, 2007 | 06:15 PM
Ranger's Avatar
Ranger
That code isn't in the 2006 service manual I have. A quick search turned up some your request for help here: http://forums.corvetteforum.com/show....php?t=1731738
And
good advice and an offer to send you the technical explanation:
Originally Posted by c6silverbullet
I have All Data program for my shop. I checked this code and here's the description "If ECM detects that the timing between the crankshaft and the camshaft is incorrect, DTC P0016 sets."
I cannot copy and paste the whole test procedure because ALL Data program data is protected. I CAN print this out and fax it to you if you want. I'm closing in 15 minutes right now, I will be at my shop tomorrow also.
Kenny
Did you follow-up with Kenny? if you lack access to a fax machine let me know by PM. Perhaps I serve as an intermediary.
Ranger
Old Jun 21, 2007 | 06:18 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
And
Ranger
I did, but my tuner said it's a crank sensor so I dunno! should I take it to the dealer?
Old Jun 21, 2007 | 06:21 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
is it affecting the car's power?!?!?!?!?!?!?!
Old Jun 21, 2007 | 06:23 PM
Ranger's Avatar
Ranger
If caught between the GM's online service manual and your tuner, I'd take the car to the dealer. Only problem with doing that is the origin of the sensor you recently installed that may be the issue.
I'd suggest another post to your original thread.
Ranger
Old Jun 21, 2007 | 06:25 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Thank you Ranger!
Old Jun 21, 2007 | 06:30 PM
Ranger's Avatar
Ranger
Thank you Ranger!
Anytime, Dashti.
Ranger
To CEL, Code P0171
