Question about oil temp
Old Jun 23, 2007 | 05:24 PM
cbrf4i1's Avatar
cbrf4i1
Originally Posted by dennis50nj
i can guarantee if you have an automatic Z51 you don't have a oil cooler. gm lied in the pamphlet's and the sales people lied. only the Z51manuel has the cooler.
Originally Posted by dave pawlowski
Not true. Water will be driven out at much lower temps, although more slowly. Heat a pan of water on the stove at say, 180 degrees. It cooks off, doesn't it?
Old Jul 2, 2007 | 04:00 AM
Nukecop's Avatar
Nukecop
St. Jude Donor '05
oil temp here recently driving to work 07 m6 approx 80 mph hitting 241+degrees 5th gear, outside temp approx 114.
Old Jul 2, 2007 | 09:58 AM
Whiterock1's Avatar
Whiterock1
Mine runs about 205-208, M-6 Z-51, at normal highway speeds in 85 degree temps. Have never seen it higher than 216 even at very spirited driving speeds. 220s is not a problem at all. I would guess that staying under 240-245 is fine with synthetic oil.
