Speed limiter
Old Jun 23, 2007 | 05:08 PM
Black C6 2005's Avatar
Black C6 2005
Cruising
Default Speed limiter
New to Corvette forum and this is my first corvette, a 2005 convertible 6 speed. I wanted to know if it had a speed limiter or chip that limited the top speed at a certain MPH ?
Old Jun 23, 2007 | 05:52 PM
repete12's Avatar
repete12
i recall someone telling me that the vert was speed limited to 145.
Old Jun 23, 2007 | 05:58 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
I think yes there's is! my tuner canceled mine
Old Jun 23, 2007 | 06:11 PM
cbrf4i1's Avatar
cbrf4i1
don't believe so, or gm wouldn't claimed 186mph top speed. i guess it is possible 186mph is the limiter but i seriously doubt it.
Old Jun 23, 2007 | 08:31 PM
30YR W8T's Avatar
30YR W8T
Old Jun 23, 2007 | 09:09 PM
Abomination's Avatar
Abomination
I can guarantee there is not one, don't ask how
Old Jun 23, 2007 | 09:19 PM
REVAK's Avatar
REVAK
There is a lot of mixed information on this. I have an 06 vert 6sp manual, when I use my predator programer, there is a page or screen that indicates a speed limitter of 186.45 mph and an option to turn it off. IF you have one, it is probably 186 mph.
Old Jun 24, 2007 | 02:31 AM
Brett Hunter's Avatar
Brett Hunter
There is a limit that is set to 186 mph from the factory. I know that this can be seen and changed with LS2 Edit.
I believe Spinmonster tested this by lowering the value and the car would not go above the speed he put in.
Old Jun 24, 2007 | 10:33 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I pulled my tune from the car and I can confirm that the top speed limiter is set to 186 and that is a stock tune. I have the ragtop.
Elmer
Old Jun 24, 2007 | 04:57 PM
1yy07vette's Avatar
1yy07vette
learn something new everyday !
Old Jun 24, 2007 | 04:59 PM
jsbeller's Avatar
jsbeller
"They" wuz wrong!
Old Jun 24, 2007 | 05:07 PM
Wayne88's Avatar
Wayne88
I don't think it makes any difference if it's a convertable or a coupe.
The Z51 rev limiters are:
1st: 50mph @ 6500rpm
2nd: 72mph @ 6500rpm
3rd: 104mph @ 6500rpm
4th: 149mph @ 6500rpm
5th: 186mph @ 6500rpm
6th: 186mph @ 4700rpm
The base model is slightly different in the lower gears, but I think the top speed is the same.
To Speed limiter
