vararam installation question
Old Jun 24, 2007 | 09:00 AM
LMBluestreak's Avatar
LMBluestreak
Default vararam installation question
Hi all,
Installed a VR yesterday with a friend in my 06 coupe. We spent a lot of time cutting the shroud, to get the fit just right. . . so, here is my question. If we cut the shroud correctly, should the filter / maf / accordian air hose all hook up to the throttle body easily, we both had to "horsepower" them on and I am not sure if, perhaps we should have cut more off the front part of the shroud...runs great btw! Oh yea, it does have the tb spacer as well. any comments would be appreciated!
LMB 06 A6 with COW tune
Old Jun 24, 2007 | 09:10 AM
dennis50nj's Avatar
dennis50nj
Originally Posted by LMBluestreak
Hi all,
hi. i had no problem it does slip over firmly if cut and installed correctly the vr wont hit the hood liner when shut you will see the mark. you usaully have to got the front out all the way to the two humps in the shrouds front. bacicly removing part of them
Old Jun 24, 2007 | 09:16 AM
LMBluestreak
Thanks, It does not hit the hood liner, and I did have to cut away about 50% of the two humps....yet didn't exacly slide over...nice color on your car BTW
LMB 06 A6 COW Tune
Old Jun 24, 2007 | 09:37 AM
Kerls07's Avatar
Kerls07
I had to call vararam because of the postion it sat under the hood. (I even bought prscut shroud from them)
I measured some areas that they told me to and they sent me out a custom cut bottom scoup that fit great. (got rid of rubbing issues with hood liner and helped everything seal better)
They say it only needs to be done that way to a couple cars.
Great customer support.
Mine was about 1/4 inch to long if I am not mistaken.
Reach under the system toward the engine and make sure where the 2 pieces top and bottom connect there isnt a gap. Mine had one that is why I started calling and explaining to vararam.
You need to put over 100 miles on it to give your computer a cahnce to reset itself before you will really feel a large difference.
good luck
Old Jun 24, 2007 | 10:59 AM
Miaugi's Avatar
Miaugi
I also had the TB spacer and I found the problem was the OEM accordion was just too long/too bulky. I ended buying two sections of silicone couplers from www.hightempsilicone.com/product/HTS350400T43BK worked great!
Old Jun 24, 2007 | 01:13 PM
DP Dave's Avatar
DP Dave
I too am having problems! I removed the spacer and still it doesn't fit correctly, can you give specific details as to how to install the two silicone couplers?
Thanks,
Dave
To vararam installation question
